- Jan 14, 2010
Despite an early rise, I have been unexpectedly delayed by a wait in the barbers.
Finally today's steps are underway!
After cutting all my brass bolsters and spacer to size I have set to the bolster proper. This is has got to be the most laborious part of the process.
I start by chain drilling a series of holes by hand:
- The blade is pretty narrow, only 2.5mm thick so I use a 1.5mm bit (oh sorry, I'll probably be using a bit of metric here) for the holes.
I now need to join these holes up. This is head-scratcher number one.
Normally I just use needle files to 'cut' through to each hole. Then file the slot square. However, most of my needle files are two thick to be able to do this, and keep the slot below 2.5mm.
Expect a short delay whilst I experiment with coping saw blades.....
....or remember I bought a fine tapering round for such an instance! Whoops.
Sloooooooow progress:
- Finally the gap is wide enough to work a flat needle file in there:
- Now it's a case of working the width of the slot. I need to keep offering the tang of the blade up so that it's a nice tight mechanical fit.
- I'm sure the pros have a quicker way to do this. I know it's common to drive the brass bolster on with a mallet. Am not really a fan of that method.
