Fixed Traditional 'Brukskniv' Builld
Thanks folks.
I wasn't sure if its a bit too brassy.....but it keeps the balance point pretty much on the index finger, which is handy.
I'm not sure I'm ready to see that image just yet!
Lets just hope he can keep dry long enough to come and have a look!
WOW... that´s a wonderful looking knife, Thom. It will be pretty good looking in my Lederhosen :)
I really can´t thank you enough, all the hours you spent etc etc... I´m just stunned, my friend.
Congratulations Andi, you've got a great knife there. Well done Scruff :thumbup:
Thanks Andi and Jack.
The question now remains what kind of sheath to make. What say you Humppa?
Really - you want to make a sheath, too?
Personally, I think a simple leather sheath would fit the knife nicely... I´ve also made thoughts about a sheath to myself... ;)
Wow - I just went through this whole thread. Scruff - thank you for taking the time to share this process. It's been very cool to see the various steps and the gorgeous results! Well done, indeed.
Sure thing hombre. You don't get any half measures from the Scruffy workshop!
You pick, this kinda style?
Or this?
You decide.
Smithhammer - I'm glad you have enjoyed it. Stay tuned for the leatherwork :)
Awesome thread...I haven't made a knife in about a year...and I am afraid my Bader won't know who I am when I step up to it , you have inspired me to get my butt back in the shop.
Very nicely done knife sir.
The bottom one is a real looker - that´s some fine leather work... I like the high carrying and the shape of the sheath at all.
I almost knew that won´t get half work done from Scruff-workshop... :)
Darn, this will be a fine setup for EDC and outdoor.
Yeah, acutally a beauty.
I hope that don´t need any Interdigital webbing for myself when the rain won´t stop and the water is rising much more... :p (galows humor is some kind of my speciality)
JT - I've not been nearly as productive as I should have been with my knifemaking. This thread is not just a gift to Andi (and the forum), but also a kickstart for me!
The bottom style it is then (or something like). And don't worry, I'll be sure to give it a drainage hole! :p
Right or left hand carry??
This just keeps getting better and better! Tuned in for further episodes on this end:)
So the Brukskniv itself is complete (maybe I'll buff it on the wheel, maybe I won't) so now it is time to dress it.
Last night was the first chance I've had to start this stage and I called upon my Tidioute #53 for some help in doing so.
I selected an area of my leather that was thickest and least flawed/marked. Unfortunately I'm running out, so there was one minor blemish. I made sure that these would be on the backside of Andi's left side carry sheath though.
The leather is naturally tanned and of about 2.5-3.5mm in thickness. The stiffness ranges across the half hide I ordered, so I select a suitably stiff piece, for this 'western' style sheath.
For the Nordic (wet-stiched) sheaths I make, I also use this leather. In such an instance though, a more supple section would be desireable (but not too much so).
You get to 'learn' or at least make educated guesses on how each hide will perform and shrink (as it does in wet-stitching) and I've found the really stiff stuff to shrink less....it must more dense and/or more 'dynamically stable' as my Garment Technologist good lady would say.
This piece was actually sourced from Finland. In my limited experience, I have found the German hide to be better quality and consistent suppleness.
Anyway, enough waffle, here's how things come begin to come together.....
Paper template:
Cut out:
That wharnie blade is sharp indeed after my fine tweaks :)
Stiching groove cut and edge bevelled (ALWAYS in that order!):
Welt pieces cut are cut out, using the original template as a guide.
Just wanting to illustrate the grip I used here:
I didn't want any fold-ups! Just took it nice and steady, letting the blade do the work, usually in a couple of passes.
I then use a skiving tool to taper the 'side welts' (the additional pieces to accomodate the hande):
And also skive a little leather on the crease of the knife:
Using a stitching wheel, I mark out where I will prick the leather, using a diamond profile awl:
Pricking is done parrallel to the edge and the diamond profile separates the leather, and allows it to close back up slightly, 'hugging' the stitch a little.
Finally, for today (or rather last night), I glue up the welt pieces using contact adhesive:
More to follow later this aft/evening.
As always, thanks for following along and please ask if I have missed anything....and no, I haven't missed the belt loop! ;)
Fascinating stuff Scruff, you're doing a great job there :thumbup:
So, to up date, I have been a bit busy and managed to really breeze through this sheath build.
Picking up where I left off, I looked to the belt loop:
It may look a bit weird now, but all shall be revealed later....
Apologies, I skipped over the dying. For this I used Fiebings #121 Medium Brown. I did not dampen the sheath before hand, I don't like it to be through dyed, or all flat looking. That said, I do apply in two passes/coats.
After leaving overnight, I glued the sheath with contact adhesive again:
Once glued I quickly re-prick the holes and them its time to saddle stitch:
Well, after a bit of a rub down with some 'Laederfedt', and a wee bit of burnishing etc its done!
Yup, that's that weird belt loop, the 'Grohmann Loop' as I like to call it, due to it being used on their sheaths:
All tucked up and secure:
A leather sheath can need to be taught to hold its shape. So it needs to rest on there for a while:
So that's it really, Brukskniv and sheath complete!
I shall look forwarded to sending it to Andi and seeing what he makes of it.
Thanks again to all of you who followed along, and for your patience.
Take care
scruff
