So are you going to be using this strictly for knife making? It looks like you're pretty handy in the metal work area, so I would assume this might see double duty?
Are you still happy with the 3450RPM or do you wish you'd gone with ~1700RPM?
I plan on making a few knives on mine, but it will be far from the main purpose and more suited to just general shop use and am debating motor RPM.
We got all the components ordered last night; GIB kit from Jamie, KBAC-27D from Electric Motor Wholesale, 1.5Hp motor, 5" drive wheel and 4" idler from Ebay.
There will be a few differences on this build. I will use a 1.5hp motor instead of the 2hp so I can run the grinder on a standard 115v outlet. The motor is also an 1800rpm unit that I plan to run with the 2x jumper enabled.
Ok, bear with me as I'm far from an electrician, I'm assuming you still picked up a 3ph motor?
How would changing from 2hp to 1.5hp change the voltage requirements?
Most higher HP motors are 230v because the amperage required for higher HP 115v motors exceeds what can be delivered over most household 115v circuits. Baldor does make 2 115v/230v 2hp motors, but they draw 22amps in 115v configuration, which exceeds even a 20 amp circuit.
Have a new GIB to assemble. Wondering why the idler arm to idler upright attachment holes are measuring .560 instead if .500. Are we supposed to have a bushing or special bolt here?
. I also have an idea for a new tool arm that I am going to try. It is based on Nathan's assertion that lengthwise grinding has not been explored enough by knifemakers. It will utilize small wheels and a highly adjustable flat platen.
Bob
Bob, I've got a GIB build in progress and also plan on using a 1.5hp 1800rpm motor on 115V with the KBAC-27D. Still debating on drive wheel size, 5" or 6". What can you tell me about your new set up? Do you like it and are you happy with the 5" drive wheel?
Thanks for any info!
Thanks anyway, hope things slow down for you so you can get caught up. I'm still waiting for my GIB kit to arrive and at this point I'm pretty sure I'm going with a 1.5hp motor running at 1750rpm and a 5"drive wheel. My understanding is that with this setup and the 2x setting on the KBAC-27D I will get the same top speed as a 3450RPM motor and more torque at lower speeds. If anyone thinks I'm making a mistake with this approach, I'm open to suggestion.Sorry man, I've been so busy I didn't notice your post. In fact, I've been so busy I haven't finished the grinder yet. Still need to build the stand and mount it.
Bob
