- Jul 22, 2009
I understand where you're coming from, and I too carry a knife for SD here in Hawaii. Just the thing is, carrying a knife solely for SD typically leaves you with a knife you won't use 99.9% of the time if you have sense enough to avoid conflict, and also because you'd want to keep the thing razor sharp and not risk blunting it from utility use.
This will be a Prac Tac topic eventually so...
I would recommend the Cold Steel Ti Lite. They only seem to have the 4" and 6", but nothing in between. If you're clever with a belt sander you could probably grind it down to a hair under 5.5" to be on the safe side, or have someone regrind it for you. Another one would be an Endura Wave. But if possible, I would consider a fixed blade and go for a Spyderco Moran or Gryphon M10.
My requirements for an SD knife is that it is quick to deploy, outstanding slicing ability, and LIGHT above all else. Remember, if you're carrying it for SD and nothing else, having 10 oz of knife in your pocket everyday will just be dead weight. I would also think I could slash faster with a light knife as opposed to a literal pocket brick.
