- Jun 30, 2011
And it can be. Along with a clip being added. Pocket carry?? Bah, NO PROBLEM! Pardon the crappy photo though;
Did you replace the scales?
First, you make the error of assuming that the dollar value of a tool is relative to the value of the user's life. By that logic, we should all carry solid platinum, diamond-encrusted crowbars. That's hyperbole there, but it's also the logical extreme of your argument.
Second, there is a point of diminishing returns on knives once you hit the $100 mark or so. Every dollar you spend past that gets you less and less. A $10,000 dollar knife will be hard to tell from a $1,000 knife on the basis of looking at the work done with it. A dependable $10 knife may even produce the exact same results as a $100 knife. May not look as pretty or last for years, but if the steel isn't worthless and you took the time to sharpen it, you'll find you can do the exact same job with it.
Amen.You buy tools that work best for your needs.
If you like Ferraris, but a Toyota Corolla will get you there all the same, why spend the money on a Ferrari? I suppose if money is there to be burned, go for it. Me personally, I like my money.I still don't see your price-point self defense approach.
It's more of a backup in this case. Mr. Glock is there as a first responder, this is just in case of the very unlikely eventuality where Mr. Glock fails and cannot be cleared. Or runs out of bullets, which in any sane SD situation is also very unlikely.If you want an EDC that you can use (even if just once) for SD, a serious person would find and study a MA or knife defense system. Then the realistic person would find and purchase knives that would enhance his techniques.
BTW, where do you get your idea that $100 is the max before diminishing returns kick in. Why is that? Do you have statistical data or experience proving this? What about imports v. USA made cost differences, promotional sales, buying used, or inflation? The US dollar has been losing valuation, so have you set a historical date for your $100 valuation? You acknowledge that spending more does improve quality, so why do you think $100 means anything?
i know that you said 100 dollars max, and that is usually what i spend on folders... but the htm madd maxx would be an excellent choice. i think they are anywhere from 300 to 500 but im not sure. I just dont think for non trained self defense the handle and blade shapes on the madd maxx and benchmade 530 can be beat. the knife is comfortable in edge up/down reverse, its fast, and easy to use with good penetration but also has plenty of belly which makes them equally versatile for edc. I dont have a madd maxx yet but i use my bm530 all the time for the same things i put my enduras and cqc13 through.
but otherwise if i was going to carry a 5.5in blade around i would just go ahead and go with a fixed blade. they are very discreet worn horizontally on the belt.
No. I took the original scale's and several grits of wet/dry sandpaper. Spent a couple of nights sanding it to my satisfaction, and then added the pocket clip. At that time I did not have the tools to drill and tap the titanium, so I drilled the holed in only the micarta, drilling them a little oversized, added some JB Weld, the duct tape of the epoxy world, put the clip screws on, and let it dry overnight. It has been solid ever since and this was done in April of 2010. I carried it for several months and that clip never gave me a problem. This is a heck of a folder with a .200" thick N690Co blade that has a convex edge that will pop the hair off! Ti liners are .110" thick and lockup is SOLID , locking up with half, .100", of the blade tang available for any wear that may occur, though so far mine hasn't worn any from where it was out of the box.
Guy, I do not have the knife with me right now, but I think I can tell you about what the thickness is. Measuring one side, including the liner, the highest point is in the middle, the palm swell, and it would be a hair under 1/4". Add the other side in and you are around .50" thick, then the standoffs would make the total around the .75" mark, give or take. It is thinner than it came as I had to take those swells at each end down a bit, but I'm a big fella' and the knife fits great in the loose style pants I wear, so it is not a problem for me to carry it, and with the deep carry clip it rides inside my pocket and goes unnoticed by the populace.
If I was going to Texas, I'd pack a Cold Steel Voyager XL(Either clip point or Vaquero.)
Good choice, I've been wanting a Triad lock. Is it/was it stiff when you first got it?Ended up getting the recurve Cold Steel Voyager XL Vaquero as well as another Great Knight:
That's where I've been looking. I just got the serrated Large Voyager Vaquero. It doesn't seem to be stiff at all, but looks like I'll need to order an XL now, because I still have plenty of pocket space for larger carry! I miss the assist of my Kershaw Ken Onion Tactical Blur, but guess I'll just have to practice more. I really like the Triad lock. It's very confidence-inspiring!Pepper spray and running shoes would be better for self defense than an $18 knife. If my understanding is correct a lot of people carry guns for self defense in TX. If you pull a knife and the other person pulls a gun you could be in a lot of trouble.
That being said, Cold Steel is where I'd look.
The truth is that within contact distance up to a 3 yard radius, it doesn’t matter if you have a gun, bazooka or bear trap, if the other guy has a knife, like it or not you’re in a knife fight and odds are not in your favor. And if the blade is already drawn, you are in a world of trouble. The Tueller Drill extends that range to 7 yards, so within 3 yards you have almost no chance. Most likely, you’ll get cut, and if you have poor training or none at all, you’ll get killed.
