I think your issues are complex enough that the true essence gets lost when communicated via E-mail. I don't own any Emersons any longer (lost my Guru status years ago) but I feel confident that EKI does their best to try to make each and every consumer happy.
In any event however, you are entitled to a knife free of defects and poor workmanship and that must be addressed by EKI ASAP
a guy on youtube called neptuneknives had a whole list of problems with his cqc 7v. literally just about anything that could be wrong was. he made a really good point about how blade centering can affect lock up.
if you break in your lock at a certain angle when the pivot loosens the angle changes and you have to break it in again
In my opinion, he's an idiot. I don't buy for a second that he didn't cause most of the issues with that knife. Have you seen any of his other "reviews"? He's clueless.
That guy complains about everything under the sun, he has also been banned from here multiple times. Maroon is a good description of him to be quite honest, alhought idiot is quite correct as well.a guy on youtube called neptuneknives had a whole list of problems with his cqc 7v. literally just about anything that could be wrong was. he made a really good point about how blade centering can affect lock up.
Chip, do yourself a favor and call the number given by 5.56, it can't cost that much to call from Canada to the states. The reason you might be getting the run around is the verbose nature of your posts. I honestly don't think that many people have the time or desire to sit and read what amounts to a dissertation on your experiences. I am not discounting your observations, but for the sake of getting things moving forward, be brief, get to the point, and stick with the facts. Call them, and be done with this.
1) Is it accurate that 154CM steel is prone to chipping ? I've read about this every now and then, but in fairness, I don't know what those who wrote about this did to their knife.
The common sense answer is, yes it will chip and no it will not. There are some variables involved, steel hardness, what you are cutting, initial angle of the secondary bevel, etc. if the steel is over hardened, it becomes brittle (same of most steels used in cutlery), if you try and keep the use realistic and within it's recommended Parameters, 154CM is a great steel.
2) What is expected to happen once a liner has traveled all the way across the blade tang ? I have a brand new 2011 combat karambit whose liner is past 50% - so far the lock is strong as it should be. Normally, one shouldn't ''have to'' even think about sending a liner lock knife in for repair. I don't know how many knives need to be sent in for liner lock issues though, so I won't speculate.
The common sense answer, again.... Any mechanical device that contains moving parts will wear over time. It's a natural occurrence, this includes liner locks. Since they obviously do not repair themselves, yes you will need to send them in. That is what the warranty is there for "Limited Lifetime" or whatver the nomenclature is. No one knows how many knives require attention for warranty issues except the manufacturer.
3) Any of you have a combat karambit ? If so, how strong is the tip ? I think any such fine tip is prone to chipping or breaking is used inappropriately, but I'm wondering about the toughness of 154CM.
I have never owned a Combat Karambit. The knife is not necessarily designed for utility work rather for self defense or offensive purposes (the name kind of says it all). The short anwer again is yes, ANYTHING can break when used inappropriately, again with the common sense, I know I know.. Wile 154CM is a fine steel used by many makers across the board, it is not indestructible. In the context of Emerson knives, my experience is that it sharpens quickly and holds an edge commesurate with my expectations.
Thanks
Many stories of those tips breaking. A reinforced-tip grind (think of an inverted spanto) would mitigate that. I traded for a super SF with a broken tip, and reprofiled it myself.I assume some of you reading this thread know a good deal about Emerson knives, so I'll ask you a few questions - I know it'd be best for me to phone EKI, but I thought why not ask it here, since like I said, many probably are in a position to answer the following queries.
Thanks
Personally though what annoys me more is the lack of a full ring spacer, which lends itself to either of the liners peeling away from the G10 scale. I do not think that is characteristic of a 200-250$ knife, especially if less attention was spent towards finish, whereas it's hard to justify the cost with such cost cutting maneuvers (partial spacer, 300 series SS nonlocking liner instead of Ti).
154CM isn't that prone to chipping, though Emerson knives aren't run to the highest RC. Being softer, they should actually be tougher. The only advantage 154CM has as an ingot steel (versus recent powder steels) is that its less likely to shear when flexed to extreme angles, but who here pries with a folder anyways?
I have never owned a Combat Karambit. The knife is not necessarily designed for utility work rather for self defense or offensive purposes (the name kind of says it all). The short anwer again is yes, ANYTHING can break when used inappropriately, again with the common sense, I know I know. . Wile 154CM is a fine steel used by many makers across the board, it is not indestructible. In the context of Emerson knives, my experience is that it sharpens quickly and holds an edge commesurate with my expectations.
You are correct, the S30V will hold an edge a bit longer, the trade off is that it Lateral stress is something that would definitely be a good test, I would be curious to see the results. My impressions are that the 154CM would flex a little more. The nice thing about 154CM is that if you hit something hard while cutting, the probability of a rolled edge vs a chipped out edge is higher. In my view that would be a better outcome.
The issue with the liners wearing between the Military and the regular Emerson is possibly the Titanium liner can and will wear much faster than the steel liner of the Military. What I really do like and think is a great innovation is the floating stop pin. Hard impacts from repeatedly waving a knife would destroy other knives.
I've seen a lot of pictures of the Combat Karambit tip, and it is thin, my thought was to get a better purchase on the material being cut. I don't know how much the chipped or broken tips can be attributed to abuse or misuse versus a legitimate use. Some people easily confuse the definitions. I'd say that if you like the knives, and they are functional and serve you well, keep them. :thumbup:
I sure like the knives, but I hate the fact that my titanium liners will sooner or later need maintenance - I really hate that aspect and it is the one aspect which causes me to consider selling them all and getting something else with no or very low maintenance.
Ok I think I know what you are saying. Ernie uses Ti for liners to save weight and also I think with Ti liners the wear is only on the liners and not he tang of the blade. When you have SS liners, yes, the liners may last longer but when it needs to be replaced, the tang of the blade is also worn.
