Great article Larrin. Thank you.
A question - How has the technology of Continuous Casting effected the "quality" of steel for knifemakers? I don't know if the steels we commonly use are produced this way or not. I imagine that the initial thickness for Continuous Cast steel is much less than the thickness of a traditionally cast ingot, and therefor is subject to less forging/rolling elongation. It's obviously more economical for the steel mills, but is it better for us?
I’m not a steelmaking expert. As I understand it high alloy tool steels are not well suited to continuous casting. Not sure how much it has caught on in tool steels, but is common for other types. It might be used in the strip steels, someone will have to remind me.
I haven't heard of those knives being made. What companies are making them?Larrin, this is somewhat off topic, but what do you think about microstructure of near-net-shape manufactured (powder steel) knives, which have very low levels of reduction compared to the same alloy rolled into bar or flat stock?
You totally did not take into consideration how the smiths spirit is imparted to the steel or the benefits of Yak Urine in the quench
Nice article, much appreciated
You don’t have to use nitrogen atomized powder for those kinds of technologies. And with choices like M2 and 440C, ground steel powder seems like a strong possibility.I was going to say that Ferrum Technology uses MIM; however I can't verify what technology they're using on the blades themselves. The discontinued Kershaw Offset has a 440C MIM blade.
I thought I saw one micrograph of MIM M2 HSS that has lots of fine carbides, but also several larger carbides, perhaps around 5-10 micron size. I've been unable to find it again, so perhaps I was mistaken. It's interesting to consider that MIM starts with fine powder, but does not undergo a forging process to refine the carbides.
All that to say... It would be cool to see as-HIP micrographs compares to rolled flat stock of the same PM steels, and I wonder if they're published/available.
Magnetic north, obviously. Otherwise you affect the curie point.Magnetic or true north?
And reason for that is because personally I don t take ALL your test relevant .HT on all that samples you test was done in most unreliable oven and temper was done in toaster oven !Hmmm..... Natlek hasn’t commented here yet.
I don t take seriously someone who write this ......We have done a limited number of other comparisons between longitudinal and transverse toughness. Z-Tuff was 45.7 ft-lbs longitudinal and 29.2 ft-lbs transverse, both at 61.3 Rc. Vanadis 4 Extra was 13 ft-lbs longitudinal and 9 ft-lbs transverse when at 64.6 Rc. No appreciable difference in toughness was seen between direction in Vanax or M390, which may be because there is less difference between orientations at lower toughness values.
Wouldn t expect drastic difference ?????? is scientific answer ? Imagine that ......I wouldn t except ?? So is there difference and HOW MUCH drastic it is ??Forging typically leads to maintaining the orientation of the “grain” along the edge rather than modifying it, such as in this simple schematic, where stock removal is on top and forged is on bottom. Therefore I wouldn’t expect a drastic difference in edge behavior.
OK I understand what was being asked about round bar vs plate/sheet now. The reduction ratio is the original cross section divided by the final cross section. With plate the width is basically unchanged so the ratio is original thickness divided by final thickness. A 10" ingot reduced to 1" would be 10:1. With round bar after you cancel out pi and everything it ends up being original diameter squared divided by final diameter squared. So a 10" diameter ingot reduced to 1" round bar would be 100:1. To get the same reduction ratio with plate it would require rolling down to 0.1".
Where is test for comparison between forged and stock removal blade ? And who done that ?
Carry on , I do not care about this topic without real proof .You ask about my opinion so there it is ..
Carbides also suppress recrystallization. Suppressing recrystallization usually makes grains finer once recrystallization doesn’t occur.Great article again larrin and thank you
So would there be more noticeable "dynamic recrystillization" of carbides in hand forging 1" round down to shape for integrals for example more so than forging tapers and bevels in to thin stock? Esp with those with vandium
Again great article
