- Apr 4, 2007
Are you kidding me? I'm agreeing with you a hundred percent. Looking back, I realize that in all my use of knives I have never, not once, relaxed my grip on the lockbar of a knife while using it. Not only that, but it's actually impossible to relax your grip on the lockbar; that is, if you're not one of those stupid "defective users". Those pesky defective users and their lack of logic, right?
No amount of irrelevant, misleading analogies will equal a valid point.
A loose grip is not the same thing as no grip. When holding a knife in your hand it is an extension of you. Even in a loose grip energy can be transfered from it, to you and vice versa. Your arm, hand and your soft tissue act as a shock absorber, absorbing impacts and transferring that energy in a way that doesnt equal a failure. Also because even with a loose grip you are still putting positive pressure on the lockbar fortifying its strength. A similar impact (possibly even a lighter one) without anything holding the lockbar or blade isolated means energy will try to take the path of least resistance which in this case are the moving parts such as the lockbar and blade. Because of the hardness of the substrate the impact will have more of an effect when combined with a sharp blow and nothing to absorb that shock.
