Cliff Stamp
BANNED
- Oct 5, 1998
The 10V was less than .010 in places, the FFD2 was .015-plus, kinda hard to measure because the sharpening land is wider on the thicker blade.
Those are actually fairly thick for a non-chopping knife. I run 0.005" and under, full primary.
I stopped using and worrying about the scale testing when I noticed in trial runs how much the numbers were jumping around for me...
It is too imprecise, what you are measuring is cutting ability not sharpness. The total force is F_0+F_b where F_0 is the cut force at maximal sharpness (wedging) and F_b is the increase in force due to blunting. A few simple ratios will show you the precision is very low and subject to massive deviations as you noted.
and how the thinner D2 blade was cutting with less force even though the edges were pretty much equally sharp as measured on newsprint push cutting and slicing, as well as shaving and how cleanly the rope was being cut.
Yes, if you want to make this point really absurd, have Krein regrind a 420J2 blade and watch it easily cut hemp rope WAY better than a FFD2 blade with a 0.015"+ thick edge. Thus the solution is to buy a knife for $20, have Krein regrind it and it will easily outperform a FFD2 blade costing 10X as much.
Steel does not cut, this is a complete case of "the emperor has no clothes". Geometry cuts, all steel does it better allow you to optomize geometry. If you decide not to, or pick the wrong steel then the performance is poor. This is why a steel like 420HC can easily offer BETTER performance than 440C as a cutting steel.
I guess I just don't have the experience or skill to get good results with the scale testing yet.
It is impossible to get very precise with it, it is just a matter of math. Anyone who thinks otherwise needs to do some blind cutting to wake up to the reality of the precision. When you first press the knife into the cord that is the force needed for the F_b at maximum sharpness, it is less than a lbs or so. Yet this is only about 5-10% of the total force, this means that all the rest of the force does nothing but reduce precision. This is why I modeled the curves to separate sharpness from cutting ability. I then switched to the sharpness measurements directly to improve precision as you noted.
-Cliff
