Those fullers are both milled. The upper example is the type of fuller I like the least. "hey guys, we bought a mill". A flat straight slot with round ends the shape of the cutter. The CPK is also milled, but has plunges at the ends and isn't flat along the groove. My favorites are like the Jason Knight example where it's very organic, curved along its length and varying in depth and width.
What is the purpose of this large chunk of metal here on the spine. Why is that there?
Again, read post #25 in this thread, and read the link. Those are written by the experts who actually can tell you what fullers are for on a knife blade. They started as a functional design element with the hugely successful Marbles Ideal knife in 1898. The people who copied the knife had no idea what they were for, so they just made blades with grooves in them because it was a popular selling point.I think they were invented for weight reduction in large blades without significantly compromising durability.
The first 1919C2 was created in the style of a commercial hunting knife that was produced by the Union Cutlery Company. And the Union Cutlery Company took their idea from a wildly successful “Ideal” hunting knife made by the Marbles Company. The Marbles knife had fullers that were quite wide and deep and were positioned lower on the blade. This ingenious design allowed the Marbles knife to be successfully flat-sharpened (by holding the blade flat) on a flat stone while in the field.
There were fullers in blades long before marbles and they had nothing to do with sharpening.Again, read post #25 in this thread, and read the link. Those are written by the experts who actually can tell you what fullers are for on a knife blade. They started as a functional design element with the hugely successful Marbles Ideal knife in 1898. The people who copied the knife had no idea what they were for, so they just made blades with grooves in them because it was a popular selling point.
Fuller ...and handy banana holder !
Reread my post.....There were fullers in blades long before marbles and they had nothing to do with sharpening.
Read the post fromNathan the Machinist above.
Hard pass.Reread my post.....
Oh my. I'm forrest gump on the bed with Jenny
The idea that a fuller is a "blood groove" is 80's movie nonsense. Cost is increased from machining and finishing a fuller groove and it adds no real appreciable benefit, maybe some weight savings. The old argument that it was like an I beam and increased the blades strength is also false, or at least not significantly measurable in a knife. On swords the fuller was done to save weight.
I do agree they look cool. I have done a few smaller blades with fullers, just because. Ben Tendick (@BenR.T. ) is the master of the fuller in my opinion.
On something short-bladed like a knife, a fuller is mostly for aesthetics. I'm not saying it doesn't affect balance or weight at all, but it's probably negligible and often unnoticeable.
Most of the knives they're on it was done because "it looks cool".
I don't think, and I could be wrong, but I don't think that removing material in any way shape or form makes anything stronger. Like an I beam, they remove material and shape it to maintain rigidity and load bearing capabilities but it's not actually stronger than a solid piece. It is more efficient in terms of strength to weight ratio in some cases though.
First, by putting in the fuller through forging, you're displacing that metal elsewhere -- and very likely making it thicker in (right-to-left) cross section elsewhere. This could make it stiffer, at least in that one plane. Second, the act of forging aligns the "grain" of the steel at a microscopic level to some degree, making it stiffer -- especially after quenching...
I can see how compacting the steel would make it denser and therefore more difficult to bend. I'm a machinist/cnc programmer by trade, we remove material for a variety of reasons and I have a good understanding of metal working but not forging.
I'd love to get educated on forging and how it changes the structure!
A structural engineer will tell you that this is completely correct. Well one slight correction- area moment of inertia provides a measure of the bending stiffness of a section, section modulus provides a measure of the bending strength of a section.You're not going to increase the stiffness or strength of a section by removing material from it. But you most certainly can increase the stiffness and strength of a section by redistributing material away from the center line, increasing the area moment of inertia of the cross section. Which basically means, more stuff farther away from the neutral axis of a bend. This gives you your sectional modulus which dictates the relative stiffness of a section
Thank you for the part about barrel flutes. It answers long standing questions I’ve had and it shows how the misunderstanding happened.A structural engineer will tell you that this is completely correct. Well one slight correction- area moment of inertia provides a measure of the bending stiffness of a section, section modulus provides a measure of the bending strength of a section.
Regarding fluted rifle barrels- adding flutes will lighten the barrel and it will change the vibration characteristics, but removing material to make flutes will not make the barrel stiffer. The alternative method for lightening the barrel is to just put it in a lathe and make the whole thing smaller diameter. A barrel with flutes that weighs the same amount as a round smooth barrel without flutes will be stiffer because the fluted barrel overall is slightly larger diameter and read the above quoted text- "can increase the stiffness ... by redistributing material away from the center line".
