- Nov 10, 2012
Don't know if someone has already shown this knife here, anyway, I'm here to show you this chinese Lionsteel/Benchmade mutant, I got from the mail today.
It's shipped in a bubble protected letter, with it's box disassembled; you can assemble it if you use it for a gift. It also came in a nicely finished black nylon bag. Good so far.
After taking it out it seems really good, no gaps between liners and G10 (which btw are full, so the knife is 205 grams), very well centered.
Dimensions:
Closed 121 mm (factory data, didn't measure)
Opened 210 mm (factory data, didn't measure)
Blade 89 mm (factory data, didn't measure)
Blade thickness 3,9 mm (my measurement), 4 mm factory statement. Blade is 3,9 almost all the way to the tip, only in the last 2 cm it gets thinner to the tip
Handle thickness (without clip) 17 mm
Blade height behind thumbstud 31,5 mm
Lanyard hole 5,7 mm diameter
Almost full flat grind
I got this knife because I liked the shape of SR1, but am left handed, so the framelock for right hand doesn't play for me. Although this will probably stay in the closet, just had to have it when I saw it
Action is smooth when opening, although You cannot close it just by pressing the axis and flipping it closed, you have to push it by hand a bit.
Sharpness out of the box - can slice 3 pcs A4 printer papers without a problem.
From imperfections, the secondary bevel is uneven at the tip (didn't watch the whole length of blade), and the clip connection point seems crappy.
All in all, for 25 dollars + 5 shipping, I am more than satisfied.
Here are some pics (don't mind the oil I've already put on and crappy phone camera quality):
Dimensions:
