Yea I may just not worry about it. The gap is almost not noticeable. Just annoying.
You could always send it my way if it bothers you that much![]()
My Sebenza is the same way...the stud was cocked just slightly when it was pressed in. So "technically" its crooked. If you look at the flat on the other side of the blade you will notice that it is also not parallel with the blade.
Most people would never notice...or look for it if it wasn't for this thread. Consequently...it was this thread that caused me to look and notice it...and being a little OCD it will now bother me. I'll ask CRK to fix it when it goes back for sharpening later...til then I'm ok with it and it'll still get used. Honestly getting that stud in dead nuts is a little difficult unless CRK uses a fixture to hold the stud perpendiular to the blade before setting it. If its done by eye...then thats where one runs into trouble.
If they're still doing it like back in 2006 then they are press fit by hand using a manual press machine which has custom dies.
The thumbstud is sandwiched between the top die and blade (which is mid air) then pressed by a hand operated lever. Probably the only way I can think of to press fit a part.
This installation requires the installer to have to eye the evenness of the thumbstud.
Higher end manufacturers that use press fitting on precision CNC cases (usually high WR casings however sometimes because they just want to have high precision machining) have to do it by hand using pretty much the same tool as well.
After a couple of weeks of pockef carry the gap will fill up with gunk and you will not notice it anymore. Use it.
That picture makes it look way worse that it really is, it is perfectly flat unless you hold it up to the light at the perfect angle.
Oh,exuse me.I do use it. This isnt my first crk or seb for that matter. It will never fill up with "gunk" however, I clean all my knives daily.
