Thanks for the additional picturesCelloDan . They are not making the wait for my own knife any easier however.
Me too, the one Maxi is making for me is in the sheath phase.
What blade lengths did you guys ordered ?
I really like the size of my Verijero for every day use and anticipate we will be using a lot camping and aboard our little sailboat this season.
I may go one day for a little bit bigger blade, perhaps 15 cm or so as well.
I can’t wait for the pics guys
I wish I had gone just a little longer and went with 8", the size of my favorite kitchen knife.
I'll go backwards if I like this one and have 2 smaller ones
I think mine will be 4.5 inches in blade length.
Thanks for the great picture too. Mine will also be his standard 1070, o think yours is 1095, correct? Have you had enough use with it to tell any difference between 1095 and any other knife in 1070 or 1075 you have used?
www.bladeforums.com
I asked for 1095 steel.
In my limited knowledge regarding steels it is what I am more familiar with through my GEC and Case slip joints.
Prior to ordering I read up here on BF regarding the differences between both steels.
As I understand, 1070/1075 are a bit tougher while 1095 may hold an edge a bit longer while sacrificing slightly on toughness.
I doubt one could tell the difference in real life use unless perhaps having two knives with the exact same geometries and using them extensively side by side.
1070 carbon steel certainly seems to be quite a popular for the larger criollos
In my mind it makes sense to use 1070 for larger, hard-use knives and 1095 for smaller ones where you may favour a slightly better edge retention ( at a slight expense in toughness) ... but what do I know
I thought I did not have any knife in 1070 or C70 and then I realized I do have one.
It's a Grohman #2 Bird and Trout in C70.
It's "second" I bought 50 % off. A little smaller than usual and with a slight recurve as the person sharpening at the factory got a little carried away.
Time to sharpen it and do some testing
The geometries are very different though.
My Verijero has thicker stock however it tapers nicely towards the tip while the Grohman stays the same pretty much all the way.
And since we are at it, here is our big "Master Chef" kitchen knife side by side with my Verijero.
The Verijero stock thickness is slightly less than on my Spyderco Para 3 ( I measured them with calipers too)
Both flat ground and of course with nice tapering towards the tip for detailed work/cutting.
On the topic of toughness it makes sense for the gaucho to need a tough knife as he would have used it for everything, from building shelter, eating, killing an animal and yes, perhaps the occasional knife fight as well for some of them.
Here is a post on BF by maker R. Trentin regarding the testing of gaucho knives.
Smith test AGC 2022
Hi everyone, let me present you my performance test and set of knives for judgment on AGC (Gaucho Bladesmith association/Brazil) I apply for the test last month, december/22, and i was approved. I also won two awards with the knives i made for the test, best gaucho knife and best kitchen knife...www.bladeforums.com
Bending 90 degrees
Only slightly related
But aren't most swords or modern recreations of battlefield swords made out of 1055?
We'll do our fighting in the kitchen.![]()
I don't knowCelloDan . I think that if you plan on "dancing" with a knife, longer is indeed better. Maybe
RayseM has the right idea and it's best to have a selection of criollo knives of varying sizes.
I wonder what would be the proper choice -- 11" or 15" blade.Here are a couple of knives to provide a sense of scale in my hand.
lol Ray, maybe we should go shopping togetherWhile on the subject - it appears I will need a new dancing outfit too.![]()
