Here's how I had my GB modded to give full access to the Spydie hole and liner lock like God intended for all knives. Seriously, its a joy to get a full purchase on the Spydie hole instead of just getting 60% of your finger in there. Same with the liner lock.
Well done, I'm doing the same mod but on both sides, I don't mind the hidden lock release but it's a write off if you have any type of gloves on.
I want to open both side to expose the speed hole completely and take in the end of choil on the presentation side slightly, I feel that's a better spot for releasing the lock and the knife tang drops down to hit my thumb nail, if I use the intended release spot, the knife drops down and the edge is cutting into my nail (any one else find this?)
I actually don't find any improvements on the GB2, the functionality isn't improved in the 2nd generation, the blade material/shape/grind are all the same, just a tad slimmer and narrower... Not sure if that's a good thing for the intended purpose, then again, the original GB is an overkill in making a super knife IMO. So I don't think slimmer and a tad shorter will make the GB2 less effective but as far as being improvements, I don't think so. Same story with the handle, slightly shorter and narrower again aren't improvements to me but more of a marketing scheme, to have something "new" to the market. If I haven't own the GB and am buying, the. I do believe the GB2 is every bit as good as the predecessor and not better,.
I think the only way to improve the GB is to give it a set of KVT bearing and a slightly stronger detent, leave everything else alone.
Spyderco should have keep the GB in production and introduce a slightly smaller version like they did with Military and PM2 and now the rumor PM3.
I'm pretty sure every one that owns the GB will buy a 2.96" blade GB with 4" handle, I would buy 2!
The GB Air is too small, they need to up the side a little bit and put a clip on it before I would give them my money
Just my 2 cents
