I've used my Militaries (I've got 9) many times for drilling, yet they haven't failed me even ONCE! I think the GB lock wore out due to regular use or something, since I have tested the liner when I bought the knife. Besides, it's supposed to be a heavy user or something like that. That's what it says on the paper you get with the knife. I've had liners fail on me, but only when these were Titanium liners, or cheap/thin liners on cheaper knives.
Jim, I though of giving these guys a call, but then again I would hate to live with the doubt of reliability. I think I'll just stick with my fixed blades for "heavy use" (tough honestly, I did not use much force at all).
Where did he say he was using it as a drill?I seem to have missed it myself. Maybe I am just not familiar with the task at hand, but I imagined him cutting into the bumper, then using the knife to cut a hole using the edge. The twisting coming from cutting a curve as opposed to a straight line.
If it was used like that, I don't really see it as abuse myself, especially if it was a plastic bumper. I understand the proper use mindset, but cutting a curved line seems reasonable...
If I am wrong, and he was using it like a drill, spinning in his hand to puncture a hole, well, guess he should be happy he didn't drop it into his foot or something as well...
I was using my Gayle Bradley to make a hole in a car bumber today. I've used many knives for that purpose, quite numerous times. While I was twisting, the liner failed and the blade closed on my index finger, HARD! After quickly fixing myself up (I hate doctors and stitches), I inspected the knife. Though it's a deep cut, and I know I need stitches, I'm old fashioned so I skipped the BS doctor treatment.
Upon inspecting the knife, I found out that if I try to close the blade forcefully, it fails! Actually, fails very easy too, not much pressure applied at all. This time of course, my fingers were out of the blade's way, as I was simply testing the reliability of the liner. I tightened all the screws, disassembled and reassembled it, but yet, I can easily make the lock fail. This is a GREAT disappointment for me, since I considered the GB as my all time favorite EDC/ hard use knife (more like mediocre, hard use=fixed blade).
It is not the first time I cut myself, but first time a Spyderco fails like that. It is my only Taiwanese Spyderco, and I overall considered it in higher quality than some of my USA made ones.
Not trying to prove anything, just decided to share my nasty experience.
PS. I inspected all my other folders, and it seems my Barong has some wiggle in the blade, while pressure is applied the liner flexes and moves slightly across the tang. The knife was never used, except on paper. BS.
Hmmm....Sorry to hear about the cut. Cannot really blame the knife though as you were not using it for what it was designed for. More than likely the force you exerted on it while you were twisting it into a bimber you deformed the lock bar and the interface isn't the same. Live and learn. It wasn't a lock failure, it was more of a failure in the use of common sense.
What give me pause is the part about the lock failing easily after the accident occurred. Sounds to me like the lock was damaged or somehow gotten out of spec before the failure.
I always keep in mind that folding knives are only designed to handle force in a single direction. ANY tasks that applies force side to side or against the spine can cause failure. Yes, most of time, the lock prevents the knife from closing but that's not what the lock is designed for.
My floor jack is designed to hold up 3 tons w/o failing but I'd be an idiot to crawl under the car w/o jack stands. The safety on my guns are designed to prevent accidental discharge but I'd be an idiot to point the gun at myself and pull the trigger.
"Hard use" and "heavy duty" does not mean fail-safe.
Sure thing "buddy", obviously you know exactly what you are doing, and it shows wonderfully. If you cannot take the good with the bad, think twice before posting your adventures in proper usage on a public forum.
To give an example of high end folder, made by a very reputable (100% trustworthy company), made for heavy use chores and show that even THAT can fail when used in ways that they were not intended, and did fail.<snip>
Also you have to understand, that the stress on the folder is minimal. Yes it was not as easy as cutting paper, but this type of job should not be a problem for such a serious folder as the GB. And it isn't a problem, for a proper GB. I bet that another knife, a GB, can do this job 1000000 times and not fail. IMO I got a lemon, or something. When I was "drilling" (just stuck the tip deep enough in the plastic)<snip>
i'll bet it would fail, again and again. it is not what folders are intended for.
I use my knives the way I use them because I've done it enough times to know it's alright.<snip>
I'm not interested!
i guess you know best, being young and strong and all.
maybe instead of insisting that you know what you are doing and this was a freak accident, you should learn something from the experience...like folders aren't designed for poking holes in thick plastic.
LOL. omg. I DID learn from my experience. Please read my second post in this thread.
THICK?! THICK???? funny joke. You obviously have a lot of experience with car bumpers and you even know which car bumper I'm referring to... I sid SOFT. S.O.F.T I could poke a hole in it with a freaking pen~! but decided the GB would be a way "cooler" and definitely more fun way to do it.
I don't know best. But I know what happened. I also know that you have no idea what you are talking about.
i would like to know what car bumper is thin enough to poke a hole in with a pen...in my 15 years working as an auto mechanic I never saw a bumper as thin and soft as you are describing. Please school me.
Yea, having the GB close on your fingers must have been WAY "cooler"
people who insist that others who are older, more experienced and smarter "don't kow what they are talking about" usually have it backwards.
