Gear Thread
Really liking this Eberlestock "Bandit" pack I bought recently. Great EDC pack with good organization and bombproof construction.
Laser cut PALS flap on the front for stuffing a layer or extra gear into, external pouch was something I added.
Adjustable harness and back padding is super comfy
And I really love the way the main compartment fully opens up with dual zippers. Fabric on the inside of the flap for attaching whatever hook and loop admin you want. Sleeve fits a 15" laptop or a hydration bladder. There's a small zippered pocket on top as well.
Vermont Gloves are absolutely the best leather gloves I have used. Having seams on outside makes them much more comfortable, and allows for more room in the fingers which helps keeping them warm in winter. They are very tough and well made, and the durability makes them less expensive than cheaper ones.
Husqvarna log tongs make picking up logs or pulling longer ones a breeze (and much easier on your back). You can grab a 3-4’ log with each hand and walk, or pull long logs out of a deadfall. Remarkably well made and tough. From gathering firewood, to clearing trails, to keeping on/in any vehicle going off road- they are just awesome. Trying to move a big muddy tree off the trail in the rain is truly hard. With sharp tongs you can grab ahold and have additional leverage to be able to either lift enough to safely cut, or slide to the side.
I got almost 3 years out of the soles on my Kenetrek Hardscrabble Hikers. The uppers are still in great condition after wearing these boots at least 5 days a week. I just sent them back to be re soled.
Big 👍🏼 on Kenetrek. They’re even comfy to climb power poles. Got a couple sets of Crispi Hikers which are performing well also.
Which Crispi's?
Here’s one, the match is outside w/ a nice basting of dog shit. I gave my taller pair of Crispies to our youngest last month. He moved to Anchorage.
I actually liked that pair more than my Kenetreks. Can’t remember the model but I’ll look it up when I get home. Just got called back to work…,
Which Crispi's?
The only reason I haven't bought a pair is that you can't re sole them.
Ok. The tall (10”) pair was the Crispi Non-Insulated Guide. They were a little more comfortable than my Kenetreks and seemed to stretch less in the width. A tad lighter too.
View attachment 2160563Exotac going strong. Striker is iffy when wet. Getting alcohol on it when I spray it … for reasons.
So it takes quite an effort to get it to strike. Seems to get stuck or just roll. Drying off typically makes it easier to strike.
Ok. So the flint stopped working and just spins.
All in all much less than the advertised 500 strikes.
I emailed exotac and, while not quoting here they said ‘lol buy a flint replacement.’
I’d say this had about 50 strikes. Perhaps the alcohol sprayed on it while lighting things on fire (making a sweet fireball) contributed to the flint wearing down, or something.
As for the o-rings keeping the lighter fluid from drying out they did seem to work well.
Damn, I have way more than 50 strikes on the one I’ve been carrying. I will say that the striker wheels are pretty damn aggressive and take a good bite. I seem to strike mine down the side rather than running my thumb across the top to keep from pushing down and it seems to operate smoother. I wonder if running a little sandpaper over the knurling to tame it down a little would help in the flint life.
Fire is one of those things that makes sense to invest in a fine lighter, but the truth is that not even a match can beat a bic lighter. One of the few scenarios where throwing money at the problem wouldn’t necessary Give you a better tool
Truth being told, edcing a bic is not as cool as the next option, but if it works, it works
Not a smoker, but I mentioned before, that I have a Windmill Quest/UST Trekker windproof jet lighter that's over a decade old, and still fires up on the first try.
It uses a piezoelectric igniter/spark. FWIW, my parents had an old gas stove when I was growing up, that didn't have a built-in igniter. You had to either light it with matches, or a lighter. We used one of those long neck BBQ lighters for the piezoelectric igniter, long after it ran out of fuel, just using the piezoelectric spark to light the stove several times a day, for years.
I was recently in a thread about lighters, and someone recommended the Windmill JP Turbo (same company. Smaller, all-metal lighter using the same tech). The Windmill company still makes their lighters, but for whatever reason, there are ZERO retailers/dealers in the USA (not since UST stopped selling their licensed version of the Windmill Quest, which they rebadged as the UST Trekker).
They're available (shipped from Japan) on eBay, though. I actually ended up ordering a Windmill Delta Turbo from an eBay seller in Japan, specifically for Winter coat pocket carry.
It's like a smaller version of the Windmill Quest/UST Trekker (Windproof jet lighter. Rubber armored. Supposedly waterproof/water resistant with an O-ringed cap that has 2 latching mechanisms to hold the cap shut. Someone mentioned that the guts of the Delta Turbo and JP Turbo are the same. It's the case that's different. The JP Turbo is all-metal without latches for the cap, i.e. it flips open like a Zippo).
Supposedly, the ONE caveat with these, is to never use them to light fireworks/fuses/gunpowder. These jet lighters have a coil of platinum(?) wire, that gets white hot, and is one of the features that makes the lighter windproof. Even if a gust of wind manages to blow out the flame, so long as the button is depressed, and the lighter is still releasing butane, that white hot coil instantly reignited the butane.
The issue with lighting fuses with it, is that the fuse spits carbon when ignited, and if the carbon gets on the coil of wire, it results in the wire burning out. The lighter will still ignite (as the piezoelectric igniter and the butane nozzle aren't affected), but you lose the windproof feature.
When the thread popped up on the other forum, these JP Turbos were listed at ~$7x USD on ebay. They're now listed at ~$109. Likewise, I found ONE retailer who somehow acquired a stash of the discontinued UST Trekker lighters, NIB, and ordered one as a spare. In less than 24 hours of posting the link, they were out of stock 😅
