GEC for switching from the bar to the banner shield.
I'm guessing there will be around 125 of these or so? I'm guessing from the production photo that they are doing a total run of 250, split between the two covers, but I don't know.. just a guess. Either way, hopefully there's enough to go around for those that want one.
The catch-bit photo brings back memories of problems with the 2016 BF #35. I'm guessing it won't be an issue because I assume they used a catch-bit on prior 2 blade runs of #46?
That is a lot of Whalers. I view it as a specialty knife and mostly for collectors. Looks real nice!That same piece of paper appears in 2 or 3 other Whaler photos and states 500 pair & 1000 pieces
I personally hope GEC makes enough for everyone![]()
I looked up the word and looked at the picture, but I still don’t understand what a catch bit is.
Catch Bit
A small piece of metal, usually brass, which acts as spacer to make up the difference between a thin pocket knife blade and a thicker spring that operates it. The catch bit is shaped so that it will not move when the blade is rotated. A pocket knife may also be designed with a thin blade and catch bit to make room for other blades.
500 pair = 1,000 total.Whoa that's a lot! Looking at the picture I figured it was 500 pair or 250 total and 125 of each of the 2 covers.
You need to multiply by 2; not divide.
Yep. Just like 1 pair of shoes is 1 shoe.
"Pair" = 2
2 legs in a pair of pants.Yeah, but if you buy a "pair" of pants how many did you get?![]()
