This one is going to be epic. I‘m hoping for the same bolster style as the 2021 Blade Forums knife, but maybe it will be a new style bolster. Long-pull or nail nick for the clip-point blade? I’m hoping for the long-pull. Also, I hope this will mark the return of the Waynorth Cutlery Buffalo NY tang stamp. I bet the punch will be the same as the one on the 98 camp knife since both frames already share the same clip point blades. Maybe the Oil The Joints U.S.A. tang stamp can fit on the punch tang. There is a lot of potential here.My HJ will be coming soon!! It looks like GEC is making their own first!!?? (I don't know everything they are going to do!!!)
Mine will also have a clip blade. I like the Spear-blade Jacks though - they look great!!
I am calling mine "the Rider"!!
CC
I’ve seen them on 14s and 15s as well I believeThe marrow bone and harness jack are calling to me. I've only seen marrow bone on GEC fixed blades, but I'm only about 3 years into GEC collecting. Has GEC ever used marrow bone on a folder previously?
This one is a 14 from the 2022 Rendezvous.The marrow bone and harness jack are calling to me. I've only seen marrow bone on GEC fixed blades, but I'm only about 3 years into GEC collecting. Has GEC ever used marrow bone on a folder previously?
-It's Bone, Kelly!!
-I'm flattered, Hyesouljah!!!
-Bladerust, I was gonna use CC Rider, but since that name has 'non-family time' implications, as I looked it up, I reduced it to "The Rider"!! Who knows?? We might be going off to find the sunset with this one!!!
-SFO, echo!!
One is for SS, the other for 1095.so across the board they voted no on the 2AB shield/barlow stamp?
Dang the knife budget this summer is on short supply those are amazing!!Pics of the marrow bone have been uploaded! They look really good, hopefully I can snag myself one of these.
Hope that's not the blade pivot, perhaps a backspring stop/locator pin?A little technical question here. They seem to use 2 mm diameter rivets for the blade pivot, even for bigger blades like these. Are those rivets made of nickel silver, as well as the bolsters? If so, is that enough to hold such a massive (relatively!) blade if being constantly used? I meen no stupid use, but say cutting something hard (again, relatively) which would require a more than mediocre pressure? Won't the rivet deform in some way being that thin? Any thoughts?
Barlows are not any stronger than a regular jack knife. The long bolster is just a marketing ploy.Hope that's not the blade pivot, perhaps a backspring stop/locator pin?
Even then, a 2mm pin seems pretty small. No illusions that these are pocket tanks, but that seems a bit on the small side. It's also located off center which makes me wonder if it is the pivot.Barlows are not any stronger than a regular jack knife. The long bolster is just a marketing ploy.![]()
Not sure how the blade size fits into the equation, however 3 years of cutting with moderate and greater pressure has not had any negative affects on the pin in this knife. I would argue it gets used as much or more than most knives.A little technical question here. They seem to use 2 mm diameter rivets for the blade pivot, even for bigger blades like these. Are those rivets made of nickel silver, as well as the bolsters? If so, is that enough to hold such a massive (relatively!) blade if being constantly used? I meen no stupid use, but say cutting something hard (again, relatively) which would require a more than mediocre pressure? Won't the rivet deform in some way being that thin? Any thoughts?
I believe most are off center.Even then, a 2mm pin seems pretty small. No illusions that these are pocket tanks, but that seems a bit on the small side. It's also located off center which makes me wonder if it is the pivot.
