Recently picked up a two blade boy's knife. Love the knife but find it harder to access the Long pull than I expected. I can get it open, but it seems to sit a little low behind the pen blade. Is this normal?
Thanks for any help.
If you have the room, try taking a fine file to the kick. I've done this to several knives to make the nail nick easier to get at. It won't take much though, be careful.
"roninelh" said;
Just to avoid a disaster - "roninelh" is talking about filing the kick of the pen blade not the main blade with the long pull.
Nothing negative meant toward your solution "roninelh" just passing on a word of caution. If "jone" were to file the kick of the main blade with the long pull, thereby lowering the main blade, it would make the long pull of the main blade impossible to access.
I know from my own life as a machinist, somethings look good on paper, but when they go to the assembly, you hear the word "Oops" sometimes. Then you modify the drawings, and make another couple test pieces.
I can only wonder if GEC is doing adequate prototype testing before releasing new models. Not being able to reach a nail nick because the other blade is partly blocking the nick, is kind of silly. If prototypes were made and really tested, dropped in a pocket and really used for a week, it would become very obvious very fast that the kick needs to be a bit higher on the main blade.
Carl.
I had a similiar problem, and I didn't think filing the kick on the pen was an option as the nick sat low anyway. Carl suggested a slight easy-open notch, which might have worked (had I not already returned it). You may also be able to raise the main blade slightly with a shim such as a sliver of balsa wood.
I had a similiar problem, and I didn't think filing the kick on the pen was an option as the nick sat low anyway. Carl suggested a slight easy open notch might have worked (had I not already returned it). You may also be able to raise the main blade slightly with a shim such as a sliver of balsa wood.
This is what I did to one of my Boy's Knives. I used a sanding wheel and a dremel tool to slowly make an easy open notch. A word of caution, the pen blade is fairly long and you don't have a lot of extra room between the bottom bolster and tip of the pen blade. If you decide to go this route, make sure your notch is far enough back that it doesn't expose the tip of the pen blade.
The trick to opening a Spearpoint main on a GEC 15 is to press down on the pen blade, sort of leveraging against the nail pull of the main. The pen blades have a large amount of downward give, more than 1/8", plenty to fully access the main's long pull, once you hook your nail on it.
Do not file the kick unless you are OK with a sunken backspring afterwards.
This problem is why the second run TC Barlows were Pen behind Spear Main, which completely solves the problem. On the first run, the pen blade had an extra swedge cut on the pile side, to increase clearance. GEC could maybe do that mod to your Boys knife, or If you are not happy, return the knife.
