Although the large Barlow bolster is a good idea, it wouldn't really look right on the #72 pattern.
Much better on the swell end #78 pattern, which is pretty much the same size.
I'm thinking a barlow-style larger bolster stamped with the maltese cross, and then a single large shield for engraving department numbers, etc.
I was thinking just 1 side actually, but 2 would work just the same. I was just suggesting that the cross shape be moved to the bolster stamp, so the shield could be more plain for engraving.
Hi I'm Mike from the UK.
I got your email and just like to say that the UK isn't the largest GEC market but depending on how this turned out I'd pick up 5-10 pieces for the UK.
It would depend on how international the chosen design is. I mean the Case with American Firefighters on the blade just isn't relevant here.
I like the fire hose idea and I don't know anything about fire hose but is it lined and would that be a PITA to separate?
I like this idea, and although not a firefighter is trained o'er three years at the international Fire Service College in Moreton-in-Marsh. And, due to the nature of my work have links with fire authorities up and down the country..
Just a little heads up regarding the bolster idea; you can't just stamp the cross into a bolster, the cross pattern needs to be incorporated into the bolster pressing fixture itself, which means that a whole new bolster block need to be made. No doubt that would add a substantial amount of money to the cost of the knife. You also can't just swap bolsters between patterns, they're precisely designed to fit the scales they're made for, with tommy-on pins matched up to holes in the scales. Again you'd need to redesign bolsters and scales to fit, and then make new bolster blocks AND scale piercing fixtures, also a huge expense. Your best bet is to work with what's out there, new shields are far less expensive than re-working patterns.
Eric
