- Apr 13, 2004
I've removed ALL of my guards, but left the table. I made this post elsewhere, but it's worth putting here too.
Worn belts do cut more like a finer grit belt, so it can be useful to keep them around once they've worn to the point that they're not cutting as well. Just keep in mind that they'll heat up the edge a lot more like that versus a fresh belt of a finer grit.
I like to rest my hands on the table, so I didn't remove it, but I did have to clear the area around where the belt passes through. If you didn't already, you'd also have to remove the black plastic side guard, remove the clear plastic top guard, and then carefully bend the upper part of the machine to create enough clearance for the belts to pass.
Even with all of that, every ScotchBrite belt that I've tried has been a bit on the small side, so they're really tight on the wheels, to the point that the motor will not start when switched on without a little assistance by hand.
Once they're running they work just fine, but you definitely want to be wearing PPE (as you should be anyway...) as these belts shed a lot of crap that would otherwise get in yours eyes and nose.
