What tips could Crystolon users suggest for getting an edge as sharp as possible using just the Crystolon fine stone (or the fine side of the Crystolon combination stone)?
Background:
Background:
- Experimenting with what is the most basic cost-effective setup you can use to get a good utility edge from a single stone. Trying the Norton JB8 for this role.
- How I use it now:
- Use with Norton honing oil.
- On the fine side:
- Start with slicing strokes with moderate pressure to set the toothy scratch pattern and get consistent bevels. I allow some slurry to accumulate during this stage. I don't consciously try to create or use it, it forms as a side effect and I ignore until this stage is done. I'll keep doing slices until a clean bevel and scratch pattern are visible, and a continuous apex that doesn't reflect light at any point.
- Wipe swarf off, add a couple drops of oil, now use light strokes to finish and refine the apex.
- Results: decent, but not great sharpness. Tried with 2 kitchen knives and 2 folders, all 'soft' stainless steels. Directly off the stone, pre-strop, I get a super coarse utility edge that will shave arm hair with significant friction, it will slice small chunks off of newsprint pages, and even push-cut cross-grain, with occasional hangups. It has a small burr if any, and even working that further on strop doesn't make much difference. Seems like one could do better, based on old threads. For example this one by
HeavyHanded
, where he gets a blade to clean cross-cuts and shaving facial hair, from the Crystolon fine.
