David Martin
Moderator
- Apr 7, 2008
Agreed, people can get a blade plenty sharp just off that stone. DM
I've never had much luck with my Norton Crystolon stones, I have the 8x3in individual stones in the plastic boxes. They cut great and feel pretty good but my edge always felt "washed out" by the slurry... unless it's D2, that steel takes a crazy edge off the Fine SiC.
I've used it with mineral oil, WD-40, 3-in-1 oil, windex, simple green and dry. I use edge leading, edge trailing, firm pressure, light pressure and everything between, the edge is still meh. I've got a few knives sharp enough to work for edc but it always seems that the edge does not last very long.
Now, give me an India stone and all that changes, crisp edge from the stone with ease and sharpness for days. Now this is an edge you can use right off the stone with confidence.
Over the past few years I've tried to refine my skills with the Crystolon stones but in the end all the effort has only brought me mediocre results. Works for some I guess, but not for me, I'll stick to the India for sharpening when using oil stones.
In the meantime I've actually developed a mild phobia of dropping my 2x8...
I have the 8x3 set and even with the fine one "made in USA" the individual stones seem to have a looser composition than my combination stone. Is possible the combination one has seen way more use and is more dense as the top layers have worn away, but I've also lapped and conditioned the 8x3 a number of times and it just doesn't appear to work as well as the fine side of my 2x8 combination stone. I don't think its my imagination - initially I was prepared to write a letter to Norton and try to get my $ back.
One of these days I'll order a larger size combination stone and compare that to my 8x3's as well. In the meantime I've actually developed a mild phobia of dropping my 2x8...
you shouldn't post links like this, he was banned!! LOL good stuff, thanks for the linkHi,Well,How about use only the Crystolon and nothing but the Crystolon (esp no stropping )?
Deburr with a microbevel after wiping /washing the swarf off the stone.
Part of the "Sharpening" playlist, explains the "advanced" tips
Norton Economy vs 420J2 : a little sharpening and stone maintenance - CliffStamp
For me the cosmetic factor is the biggest reason to not use the Crystalon coarse.
Honestly to look at the grind pattern one might think a closer comparison might be a fine DMT to the fine side of a Crystalon, but only on the high Vandium steels and at high RC. The non-super qualities of the SiC stand out a bit, end result is the finish being a good deal more refined than what you'd get off of more budget friendly steel.
Off the coarse DMT I'd expect the draw numbers to drop a little or stay the same, and the pressure cut ones to go up several lbs.
I've noticed that. I don't have many coated knives but have a couple where I liked the knife and the only option was dlc coated (example: CS Recon). With coated knives especially, when used on Crystolon, you see these light scuff marks just above the secondary bevel. And it looks terrible.
ETA: Is this the main thing in your view that prevents people from using the Crystolon F grit more frequently as an all-purpose coarse sharpening grit? Bluntcut mentioned this issue too.
I find it interesting that your numbers above show the fine Crystolon performing reasonably close to the DMT EEF. If this holds up consistently across commonly used knife steels, it would seem a lot more time efficient. You could sharpen just on Crystolon F, and done, versus progression on diamonds such as C/EF/EEF. Basically getting you the same results for less time.
The potential issues with that: the cosmetic thing you mentioned, and the possibility those results vary depending on knife steels.
Crystolon works fine on M390. Got a hair-shaving, crossgrain-cutting edge on this Kershaw tonight. Then tried out a 400/1000 SharpPebble SiC, this put an even nicer finish on it and increased sharpness noticeably. With this one could potentially have an all-SiC solution for super steels, if you wanted to stay cheap and avoid diamonds. Have to confess, that finished edge looks REALLY nice, it got even better on the SharpPebble. And the feedback from both stones is far nicer than my diamond plates. I'm so conflicted.
The finish on edge in this pic is after Crystolon fine:
The SharpPebble. Initial impression from 1 usage: a nice SiC waterstone and paired with a Crystolon JB8, could be a pretty end-to-end affordable solution.
