Well from further experimenting with my Kershaw M390, made a few tentative conclusions. These fit what was expected, but good to validate.
1. You can get a good utility edge on M390 directly off a Crystolon fine, plus strop with cbn. For somebody not looking to whittle hairs and do other parlor sharpness tricks, this is a perfectly usable real world edge.
2. You can get a noticeably better edge by using the SharpPebble stone, first the 400 (320 ANSI) side, then the 1K (500 ANSI) side, finishing with light edge-trailing strokes on a clean stone, plus strop with cbn. The SP does make a noticeable improvement that, IMHO, is worth the $26.
3. But I got head and shoulders the best edge yet by sharpening first on DMT coarse (325), then adding DMT EF (1200), then strop with cbn. This edge does all the paper and receipt and paper towel slicing tests effortlessly, and hair pops off your arm onto the blade. You could not get close to these results with the other approaches.
The real game-changer with M390 IMHO: you've gotta use high-grit diamonds, in this case, DMT EF or higher. There's not a better way I've found yet to get an M390 blade extremely sharp.
Next thing to test: go back to steps 1 and 2 above, tack on the DMT EF after using the Crystolon F, and after using the SP 500 side. What I hope to find is I can use coarse SiC stones plus high-grit diamonds, and can get results as good as (3) above, where I used all diamonds.
