I finished the knife and gave the handle a wrap that I "invented'. The wrap is made with two strands of contrasting color paracord....red and black in this case. There are two holes through the tang...a 1/4" one in the front and a 3/8" near the butt.
I fuse the ends together on about six feet of cord, and use the two cords together to make the beginning of a turks head. Since there are two parallel cords, it appears to be twice around already. There will be a pair of cords on the outside of the knot, and a pair on the inside . The inside ends are to be the short ends, and the outside ends are the long ends you will tie the handle wrap with.You stick the ends through the front hole from the same side.Pull the turks head tight and then use CA to glue the short ends down on the tang just shy of the butt end hole. Cut the excess off. The long ends are pulled hard to draw the ends down from the turks head. Look at the photo of this side and you will see how they "roll" the knot under. The red and black ends are separated ,and run opposite directions around the sides of the tang, then tied in a square knot on the other side. You just go from side to side, tying square knots. I reverse the knot "direction" each time to make the pattern livelier. Once the knots reach the end hole, I start wrapping around and around the tang until there is no more room in the 3/8" hole to pull the cords through. I loosen these wraps, bring the ends under them, and out by the last square knot. Then I pull the wraps tight again. Once everything is snug and straightened up, I cut the ends off between the last square knot and the first wrap.
There may be some "fuzzies" where I snagged the cord with my awl and got a few strands of nylon thread pulled out. Use a small flame and carefully melt these back to the cord. Straighten up all the square knots, then apply thin epoxy ( I use System Three clear coat) to the cord with a flux brush. Use just enough to wet the cord fully. It will absorb and look like it did before the resin was applied, but when the resin cures, the wrap will be solid.
This wrap has a nice oriental look, so I chose it to go on this blade with the metal from China.
Xie Xie, hammerfall.
The knife was ground to a near zero flat grind, and then sharpened to a rather acute 10° edge (20° included angle). It cuts very well. It is a toothy cutter, not a slick slicer. It will go through a piece of rope in a flash. It will cut paper, but grabs a bit. After I abuse this edge for a while, I may re-sharpen it at 15° to see what the difference is. Next deer season, I will loan it to some hunters and have them dress out several deer in a row with it. I will ask them to skin it, pop the joints, split the breast, and cut up the deer to see how tough it really is. I will post an update this fall on how that goes.
