Good edc/work folder under 70 bucks
Chris "Anagarika";10713198 said:
So perhaps go with 3.5" manufacturer spec. This Hold Out might meet the requirement:
http://www.bladeforums.com/forums/s...ok-Cold-Steel-Hold-Out-II-folder-new-for-2011
Exact post discussing the length: http://www.bladeforums.com/forums/s...-II-folder-new-for-2011?p=9727966#post9727966
it might but im still a little weary, the law here is ultra strict and basically if its close its too big
i basiclly dont wnana go over 3.75, (yes that .25 of an inch matters)
A number of folks have suggested the Buck Vantage Pro. I have to say from my experience this is an excellent general use knife done in a top drawer steel. The pocket clip is tail mounted so that the knife itself is almost completely unexposed. Pocket clip can be reversed for carry on the other side. There are three different ways to open the knife with one hand: 1) flipper tab, for a flip-n-snap one-handed open -- very fast, 2) the thumb hole, for a more "civilian friendly" one-handed open that doesn't startle onlookers, and 3) the thumb-n-forefinger pinch of the thumb hole, flipping the handle down.
The blade is a high grind, which makes it kitchen friendly (you can slice food and it doesn't act like a splitting wedge, tossing food off the counter). It's happy doing tomatoes. I've made salads with mine. Does fine with salami and cheese.
It's also sharp out of the box, and with just a little attention to dressing & polishing the edge, it becomes hazard-sharp.
It will do a day's work without complaining.
I'm a fan of the Vantage Avid, but that's just me liking the Sandvik steel. If you cut a lot of cardboard, the S30V will wear better.
If you're using this in a utility setting, a long blade isn't going to help and will, in fact, be more clumsy. Something between three and four inches should work fine.
I don't recall if I saw any recommendations for the Kershaw Needs Work in the thread so far, but in a utility environment, this is a serious working blade. It's an assisted opener, has pocket clip. It's bigger than it looks; Wharncliffe blades can be like that.
Frankly, if I were going to be in a back-room utility cutting environment, and I knew that I'd be cutting a bunch of cardboard, I would carry a second knife.
For your scenario I might, for example, carry something like a Vantage for general use and something like the CRKT Edgie 2 self-sharpening knife for box cutting and such. I have some of the original Edgie knives. The first version was a sheepsfoot blade, sharpened with a sort of one-sided chisel grind, and it sharpened itself every time you closed it. I don't think the first one had a lock. The new design is symmetrically ground and has a backlock. It's a Wharncliffe blade, so you have a usable point for penetrating packaging when needed.
I could get a Vantage Avid and an Edgie 2 and probably stay under $80. If carrying a second knife is a bad idea for you, then disregard that part.
I saw some Spyderco suggestions. Spyderco is quality that needs no apology. Something like a Manix 2 would be all the knife you'd need in a work environment. Seriously, take some time to look at the Spyderco stuff.
It's too bad you can't carry a fixed blade, 'cuz there's a few Mora offerings I'd suggest. Those knives are real users.
In general, I wouldn't get a really large knife. Hard use doesn't imply size. You need excellent control of your blade, and the longer the blade is, the more control you have to impose.
Hope some of this is useful.
i was never a spyderco guy but im leaning more towards then, looking at the endura 4 full flat ground frn handles in a colored handle or a spyderco native in a black frn (there both about 50 bucks and i can get a secondary box cutter) just use the knife for the cutting of tape and plastic (where the boxcutter would be a pain)
would u reccomend 1 of them over the other?
i also dont like assisted opening knives, i feel more comfortiable opening them under my own force
I didn't read the whole thread. So, forgive me if this has already been posted. I saw you mention that you liked kershaw. What about an S30V blur blem. Kershawguy sells them for $49. That's a hell of a deal.
Another vote for the Endura 4. Blade, handle to tip measures 3.75 inches. I got a green handled one for Christmas and got my girl an orange handled Delica. I love this knife. Lots of choices in handle colors, good steel, good grind, multiple clip configurations, great QC tolerances, razor sharp out of the box and a sturdy knife for the price. They can be had for $50-$60. I like mine so much I'm thinking of getting one in every color....
I've got myself a couple of Delica's and I must say they're great knives, but not thé working kind of knives that can stand through a lot.
Are you going to beat it up, or just cut cardboard 'n stuff all day? If the latter is the case, a Delica would be fine ànd a great choice. If you need a knife to do heavier duty tasks, get yourself a Buck Vantage Pro as a majority in this thread already told. Seriously, it's a beast.
If American made is not an issue, nor the steel (you said you sharpened regularly so that wouldn't be a problem though), I'd seriously recommend you to check out the Enlan EL-02 (or EL-02B). These guys are workhorses, seriously:-).
i think enlan EL-01 is a nice choice for you,it's very...very cheap,in my place you can get it with 10bucks
+1^
I always recommend this knife and no one seems to care about it!
It is a very hard use knife that you can beat on immensely and not worry due to the fact that it costs so little.
If the "made in China" doesn't bother you I highly recommend it.
I trully believe it is on of the best knives I ever handled!
endura doesnt go over my size limit no matter how u measure it up. neither does the kershaw blur, but almost all the cold steel knives that say 4 inch go way over by nj measurements because of the aera behind the edge that is just steel, thats measured in blade length here.
but then again i dont reall know either... i just dont wanna get it and be like oh man i cant carry it without risking breaking the law
My favorite work knife in that price range is either the Endura or Delica. I am an electrician and a good work knife is an essential tool. I have finally settled on the Endura as my #1 work knife because it is light, disappears in my pocket and its relatively inexpensive. Lately I have been carrying a ZDP-189 Endura and for me its the perfect work knife. I know its a little out of your price range but if you can afford to upgrade to ZDP it is well worth the $.
Buck Vantage
This! I just got the Vantage Pro a couple weeks ago to carry as a work EDC and it's been great. G10 handles, S30v blade, low ride pocket clip, flipper, and a solid liner lock. The blade shape is just about perfect. A real bargain at it's price point.
