Great steel for slicing and not fouling....
Thanks again for the info! I'll work on myself then...But yeah...Thanks a lot! :)
it is important to remember your on line persona is determined by how and what you post. voice inflections and facial expressions are clearly meaningless here. there is only the typed word, and messages are sometimes misinterpreted.
as with any community, there are behavior expectations by which we all must abide.
good luck finding your knife!
You are right, totally. Thanks for the advice! Have a good day sir!:thumbup::)
If you gave us what you're willing(want) to spend, some of us could give
you specific knives with specific steels to take a look at.
Just a thought..........
There's a bunch of great options of steels listed in this thread that would
do the job. Knowing what you want would help narrow things a ton.
Good luck in finding what you want. :thumbup:
I want a blade that will slice through flesh as if it were steamy hot butter. Yet I want it to take the punishment of contacting bone if encountered. I won't be hammering or batoning with this knife. Thank you much.
Take a look at some Rat's or Bark River..........better yet, take a look
in the custom knife makers forum. Plenty of stuff there and you'll have
something unique. You can buy something they have on hand or have
something made to your specs.
Again, good luck. :thumbup:
Thanks a lot sv! You go easy buddy! I'll def check those. :thumbup: :D
Pretty much any blade steel will slice meat effortlessly with the proper (thin) geometry. What you want is something that will take a fine edge that is not easily damaged on bone. The most important attributes will be hardness and toughness. You don't want the edge to chip or roll when it contacts the bone. Abrasion resistance is of less importance because flesh is not particularly abrasive and you hopefully won't be grinding the edge on the bone (more accidental bumps).
to follow up M4 is used in national cuting competitions by most everybody because it can be ground thin (like 10 degrees and cut real good) w/o chiping or roling (Disqualification)
In my opinion, you just described the bark river gameskeeper. A2 tool steel, excellent geometry and heat treat.
There are other tough steels as well, some include, cpm 3v, infi, 5160, 1095, S7, 52 100. All of these steels, when done properly are very tough, and should not give you a problem.
All Fehrman Knives and Zero Tolerance 0100 are made of CPM-3V.
It's not a difficult steel to come by in bar-stock, either. (Though with Curcible's recent problems, I don't know.) Though, in my experience, it isn't the most friendly to work with. There is considerable extra cost in abrasives and time that goes into a 3V blade.
Thanks for the heads up, those are amazing knives. I knew about the Fehrmans but not the ZT.
The prices for 3V bar stock are not too bad, $60 will buy you a 1/8" x 2" x 36" piece. It should be easier to grind than S30V, though that doesn't say much. I'm sure M4 and 10V are much worse, and cost more for the raw steel.
This knife was done primarily with files and sandpaper. I wanted to kill myself. Ten inches of CPM3V. I don't even want to see a bar of M4, (I know I wouldn't be able to resist).
sorry for the thread drift :)
Dude I don't know what thread drift is..but you're forgiven..AND THAT IS ONE BADASS LOOKIN PIECE OF BLADE YOU GOT THERE! Holy cow! I mean dang...ouch...That's intense lookin! I DIG IT! Thank you very much!:D:thumbup::thumbup::thumbup::thumbup:
I'd say pick out the model that best suits you from Dozier ( D2), or Bark River (A2, and now a model in CPM 3V also.)
If you have time and want something very special Talk to Phil Wilson and he'll create what you need. I'm not sure if he's taking orders now, but at times has some stock on hand. http://www.seamountknifeworks.com/
Lots of good info on steels he uses on his website.
