Green Micarta Liner Lock
That is an amazing knife and at a great value to boot! I love that you use A2, there need to be more folders using tough tool steel like that.
Looks great! Beefy A2 blade, very nice lines. I hope fastevo posts more pics and observations.
I'd like one too. Let me know when you make more.
I didn't get it!lol I was a second or two late ....... Or I would happily post some pics, and rub it in!lol Regards, Steve
LOL! I thought you were the lucky one!
Anyway, lucky buyer: post some thoughts when you get it!
Hey Ron, If you have a list put me on it also !
I would take two of them... I can even send a
deposit to secure a spot...
Thanks...
Hell, put me down for one too----that's one of the best deals I've ever seen on here. :thumbup:
Thanks to everyone for the interest in the knife. I hope senoBDEC will post his thoughts about the knife. I personally loved that knife. I took the advise of other knifemakers on this forum and priced it at a reasonable price. I don't plan on doing this for a living. I generally work 6 to 7 days a week, but when I get time I enjoy knifemaking. For everyone who was interested, I will be making more I try to make 10 to 20 at a time to keep heat treating costs down; so it takes me awhile to complete a batch. Again, thanks so much for the interest and all the nice comments.
Ron
I am new to this forum but would love to get one of these if possible. Since I saw it I have been looking for a similar knife but not found one I liked as much. I can send a deposit if nedded and will upgrade my acoount to accept PM's. That is a great knife.
Stats (apologies - all in metric):
Dimensions:
Closed length: 12.9 cm
Open length: 22.4 cm
Blade length (tip to bolster): 9.35 cm (also edge length)
Handle thickness: 1.4 cm w/o pocket clip; 1.9 cm with pocket clip.
Blade thickness: 4mm
Weight: 7.1 oz.
Materials: (from Ron Flaherty)
Blade steel: A2, heat treat by Paul Bos to 60 RC
Liners: 0.63 6AL4V Titanium
Locking system: Liner-lock, scalloped for grip.
Pivot: 1/4 hex stainless (dual screw)
Bolsters: Stainless steel
Scales: Green Canvas Micarta
"Washers": Phosphor bronze (not washers per se - explained later)
Held together by hex screws.
Positives:
+ Big, solid folder with hardware to match. Heavy-duty hardware and liners, and a dual pivot (adjustable from either side) with large stop-pin.
+ Nice thick blade, shallow hollow grind to a wide primary bevel. Entire blade is beadblasted (including swedge and primary bevel) except for the satin-finished flats (with maker's mark apparently in ink-type).
+ Blade is centered when closed. No blade play, horizontal or vertical when open.
+ Action is very smooth, there is a slight "click" as you overcome the detent, and it glides open until the liner-lock engages with a satisfying "schwack!". Can thumb-flick it open quite easily.
+ PB washers/"liners" -- Ron basically took some PB sheets and cut them to shape (of the handle) around the tang and beveled the edges slightly. These aren't really washers, but they work very well.
+ Single, RH thumbstud - very wide and comfortable, and well-placed.
+ Edge is substantially sharp. Slices paper with ease, but won't pop hair.
+ Solid liner-lock, locks up 85% just at the edge of the tang. Scallops are even, neat, and work well.
+ Jimped, raised thumbrest. Naturally placed where my thumb rests and VERY grippy.
+ Ergonomics are very well thought-out, sits nicely in the hand, secure, but without being too restrictive re: grip. Slightly curved downwards, predisposing it to forward grips. Index finger choil is very wide and smooth.
+ Bolsters - brushed, satin finish.
+ Deep-carry pocket clip (stainless)
+ Green Micarta scales are flat, satin-finished.
Negatives: few minor issues - mostly fit/finish:
- Couple of places where the counter-sunk screwholes are slightly uneven, hardly noticeable. Similar very small mistakes are find here and there on the liners.
- sharp edges on inside and outside of handle liners/scales and scallops - took me 5 min to fix.
- Thumb-rest can be abrasive. Scrapes the hand as you go in and out of your pocket. Perhaps blending it into the rest of the blade might help. Mostly I think it's just the space the folder takes up.
- Slight mis-fit of one of the GM scales near the very butt. Gap is noticeable, but cannot even fit a piece of paper in it.
? - secondary bevel is slightly uneven in width near tip and near tang of blade.
? - Prefer a slightly stronger detent.
Frankly, I'm not sure how to sharpen the tip properly on my knives - they always end up broader and wider there. This doesn't detract at all from functionality.
Suggestions:
First, I think actually beveling all the edges of the folder, especially the bottom edge, and then rounding the handle (swell) overall would make it more comfortable to use. As it came, IMO, the edges were too sharp for prolonged use, especially for such a thick folder (makes it more noticeable to me). For the linerlock, another option other than the small scallops, would be to make one large scallop with a wide, convex file - more comfortable and still gives good grip.
I think a choil right behind the edge would suit this folder model admirably - It would only require a less material cut from the blade tang and reshaping the forward end of the handle and bolster. Perhaps making the primary index choil slightly smaller?
OVERALL
This is a beast of a folder. It has its minor flaws re: fitting, but mostly things that just take practice or time to fix. I think comparing it to the original Spyderco Chinook might give you an idea of it's size and weight. The blade maintains its thickness until tapering smoothly 1.2 cm away from the tip. The liner-lock is substantial and very solid - no bladeplay.
All in all, this is a bargain for a custom, working folder.
senoBDEC, thanks for the review! Sounds like a steal at the price. Looking forward to the pics.
Pictures: - click to enlarge. Apologies for the poor quality - A. I suck and B. My borrowed camera sucks.
Comparison to Boker M-Type and Spyderco Military: Basically, Ron's folder (Model 1) is thicker, heavier, and has a similar blade length to the Military.
Note lock thickness - within 0.5 mm of M-Type framelock.
In-hand Comparison:
You can see why I think a choil here would be a good idea.
I love the honest review. It just makes me want one more. I like that is a large solid well built knife. The few minor issues mean it will get used and not just a safe queen as the looks may hae led me to believe
