Point of order Jerry, may I bring up for discussion the subject of a skull crusher?Yes, that has most of the key points.
Jerry
I hope there's not steel on titanium contact with the lock....surely not!![]()
This was in Jerry's OP.....Hardened Stainless.Why is it called the BLOCK lock? Once you see the inner workings of this folder, you will quickly note that a large block of hardened stainless steel (58-60 RC) is moved forward by a compression spring, not an omega spring, to ensure the proper seating of the lock block.
Maybe a couple of ceramic bearingswho knows, I was just guessing…
... So, in reading some of the above comments, specifically those with the diagrams....
Is it an accurate assumption that this folder will not be very easy for disassembly to just clean & reassemble, or anodize the Ti frame & reassemble?
And- If it can be disassembled by the owner:
Will the warranty cover disassembly for basic reasons or mods (like deep cleaning/lubricating the folder or elctro-anodizing only the frame, without any modding of the BLOCK lock piece(s) or blade)?
I'm actually digging the fact that while most of us were expecting the Off Duty of folders in thickness (The finished model, or Proto at least, will have the key parts that are detailed in the app. We know this, because Jerry confirmed as much <posts # 17 & #18>.
That's a lot of parts even if he pared it down by just half on the Proto vs. those detailed in his original application!
So yeah Jaxx, it boggles my piglet brain how all that "stuff" is gonna nest in an integral handle.
However, I have zero doubt that if anyone can pull it off, it's Jerry Busse & Co. or else I wouldn't have ponied up the loot on mine. No regrets.![]()
Maybe detail #104 is a channel held in with hidden pins <? If so, that'd be a neat trick to install in an integral handle!
UFFFFDAAA.....Been there looking for that run-away spring. That brings up the question of Replacement springs?I feel it's made for easy cleaning ... that's why there are only two screws in total. Now that spring ? I can see looking for it on our carpet![]()
With all the Hog's "inquiring minds want to know" asking about disassembly seems like that is forgone conclusion.
