What I hope, believe it or not, is that I've seen the end of innovations until I've seen some evidence of shipping of products that have been ordered.
You know by now, Guy does what he does, and when he does it will be when it's done.
At the expense of highjacking this thread, I've got to tell you this: I read that Silver had given a "guesstimate" of 2019 for the GSO 6 which was extrapolated based on the current production and fulfillment pace. If such scenario holds true and proves to be correct, I don't care if it's going to made out of Valyrian Steel and all tweaked out in the same fashion as Longclaw as I will just lose interest by then and will be done with this!
Valyrian steel AND a hat though... whoa.
Sent from my XT1254 using Tapatalk
I received my shipping notice last night. The order was placed on 4/11/16.
Hey Ellie, who is the everyone you're talking about? Is this a problem with the water-jet people or something that Guy is figuring out on his end? Just curious, not looking to spear you guys. I know the blade is already cut when you guys get it in shop, but is the primary bevel already in place or is that something you guys do in house also? Thanks!.... Future runs should not run into the same issues now that everyone is learning what to look out for.
The Cru Forge V blades are not suffering the fitment issues we are seeing on the other GSO-4.7s. So most of those orders have been built already and will be ready to be packed up as soon as Guy has them sharpened. As a result, those should go pretty quickly at this point.
The reason these aren't running into the same issues is partly because the steel machined like butter, especially compared to the CPM steels. The parts that do the machining wear out a lot sooner with the CPM steels, requiring more changes. If the operator doesn't notice that slight change for a while you can end up with a range of blades that are within tolerances, but still not quite perfect. Stack that with the tolerances between handle material densities, and any other variables I'm not thinking of, and you could easily end up with hot spots in your palm. Most of the time, things go together perfectly (or at least with a slight reaming of the fastener holes to get any slag out). These GSO-4.7s are that other time. I believe that is largely because they were one of the first runs to be cut with the water jet and then machined to size. Future runs should not run into the same issues now that everyone is learning what to look out for.
