I had the same thing last year on one of my low grit Orion stones.Just received my set of Venev Orions and I've got to say I'm disappointed in the QC. The thickness of the diamond layers isn't very consistent. More significantly, the F80 stone I received was nowhere near flat. The blank itself was warped, and the diamond layer right along with it. I was going to send it back, but then I noticed that the diamond layer is 4mm thick on that stone, versus the 3mm they're supposed to be. So I figured I might as well lap it flat, since I'll still have more than 3mm of diamonds even after I remove a lot of material.
Good idea, but too late.3D Anvil, got a set of used original formula KME Venev's off exchange, and a 2k Venev from Gritomatic store at big river, most backing plates came warped like yours. Konstantin advised putting tape on backing plate to compensate. I used layers of blue tape and they work fine, adjusting thickness using KME diamond stone as flat plate reference.
Did try to bend one of the two 2k's straight, but bond material cracked, my fault was technique, should of added heat and been more precise with locating and bend width jig. Still keep it around thinking I will fill crack but even 1200 is too fine for my uses anyway. This is first time I've seen and heard new formula Venev's warping. Might experiment flattening by adding tape before using grit to lap. Different grit types and sizes will effect stone surface, so you can adjust, within limits, surface to meet your needs.
I use the 60 120 400 grit for all the Venev stones now matter the grit because the resin isn't rock hard there's no need to got past 400 grit.I already had read about using Bar Keepers Friend for cleaning the stones, so I purchased the powder and use it for cleaning. It works great, and as you mentioned, its easy and cheap!
The grit progression you stated for refreshing the Venev stones, do you use it for all different grit stones the same way? Also, I assume the glass plate should be as flat as possible, right? Definitely something I need to check!
Herbert
I've experimented a lot with using only 1 low grit silicon carbide (like 60 grit) on all of the Venev stones, and it works perfectly fine.I use the 60 120 400 grit for all the Venev stones now matter the grit because the resin isn't rock hard there's no need to got past 400 grit.
You also don't want to just use the 60 grit and that's it you don't want really deep grooves in the resin that can break off and chip away,if you just used 60 grit then the grooves would be deeper and you'd have a lot of tall ridge's which is what you want to avoid.
You will also find the Venev stones stay really flat and you really only need to powder for refreshing the stones to expose more diamonds,I just wait until mine start cutting really slow then I refresh them,and never use a diamond plate of any kind to refresh or flatten them you will tear diamonds from the Venev stones.
That's my experience, too. With the Venevs I don't see any reason to go above 120, even with the F1200 stone. The sic powder breaks down, so after a few minutes it's a lot finer than 120 anyway.I've experimented a lot with using only 1 low grit silicon carbide (like 60 grit) on all of the Venev stones, and it works perfectly fine.
Yes, the stone surface feels slightly rougher and yes there are slightly deeper grooves than if you had used finer silicon carbide, but the bond is soft enough not for it to make too much of a difference.
After flattening with low grit silicon carbide, I use a dressing/conditioning Nagura stone (Like the King 8K Nagura, or Gritomatic Bodrid stone as an example). Do a few seconds of rubbing the stones together under running water, and even the finest grit Venev stones smooths out perfect in no time at all.
What about Venev diamonds do you prefer over CGSW's diamonds? I enjoy Diemaker's threads n posts and users reports, so I was inclined to include them in kits I'm building for two other family houses.Comparing Diemaker's bonded diamond stones (CGSW, Matrix) and Venev's, I prefer Venev's abrasives, but Diemaker's QC is on another level. He uses thicker aluminum plates and the uniformity of the stones is much better.
It's not so much the diamonds as it is the bonding agent. Venevs just seem to load up less and clean easier. They also seem to be semi-porous, so they stay wet longer. Diemaker's stones don't absorb any water, so you have to stop and wet them often.What about Venev diamonds do you prefer over CGSW's diamonds? I enjoy Diemaker's threads n posts and users reports, so I was inclined to include them in kits I'm building for two other family houses.
Well, the toohr #3 is different... the problem is that moderator doesn't allow me to post a link to the aliexpress site while the enbedded image doesn't work from some strange reason.I can't say who copied who, but I can guess.... That Ali Express sharpener looks very much like the SJ Multigrinder sold by SchleifJunkies at about 10x the cost (and obviously higher quality).
Because it’s against the rules.the problem is that moderator doesn't allow me to post a link to the aliexpress site
Yep, I understood, it was written in redBecause it’s against the rules.
