Skag you also need to know that the Cherry Red we speak of Is Not A real Cherry Red like you see on a Bing cherry.
It's more the red that you see on pie cherries and is pretty close to a neon orange.
The magnet is the best way to tell when the steel is at the critical temp and is the method I use.
And if you're gonna use a home style butane torch please bear in mind that it just won't get the knife hot enough.
They will work on thin and narrow blades but not a khukuri blade.
So if you're dead set on doing this to the little villager find a friend that also has a butane torch,then go get 2 bottles of MAPP Gas and do like Uncle Bill has said.
"Use the visegrips and a bucket of water to keep the handle and the top of the blade cool."
Get your friend to help and use the MAPP Gas torch on each side continually moving the flame up and down the blade slowly and
in unison at an angle so you won't burn one another and when it gets critical temp dunk it in the oil or water.
Oil is best for a beginner but have a lid that will fit tightly over the bucket or whatever you have the oil in just in case you have to put out a flare up fire.
And you don't have to get the steel polished, just get it back to the grey color all over so you can see the colors come up when they start changeing.
Sandpaper works alright for that.
The village blade is gonna be rough anyway.
And it's a good idea to have a bucket of water handy to dunk the blade in when "drawing the blade" because when it gets to the light straw to bronze color it will continue to change rapidly unless cooled immediately, ruining all your efforts.
Personally I would leave it alone because sometimes it's nice to have a blade you can sharpen with a couple of rocks, One for an anvil and another for a hammer stone.
You can gently tap an edge back on the knife getting any impacts out.
Then you can us an abrasive rock like sandstone to put an aggresive edge on the knife.
A lot of indigneous people around the world use this method quite successfully.
Try it for a while first and then decide if it's worth going to the trouble for.
