Yea, I mean it depends on the ht. Most of the China stuff rusts super easy. I mean unless you take care of them. My China d2 rusts unless I oil it. The USA stuff doesn't seem to rust easy at all. Go figure.
I was a serious holdout but they've worn me down a bit.
My 3 most carried are US designed and manufactured but I do appreciate the variety and innovation that the aforementioned have to offer.
Right now I'm chasing a couple of Italian made folders that will be released this week, lots of innovation going on in that neck of the woods as well.
All my D2 is American made, so I can't really speak to Chinese D2 rusting, but that seems odd. So long as the steel is the same composition and good HT, the steel has no idea where it was smelted. I wonder why it would make a difference.
Everything I've read on the subject it says it does. In fact the difference between 3v and delta 3v is the heat treatment and d3v being way more corrosion resistant. Heat treatment is a profile or recipe so to say. Of different temperatures and hold times for different events to happen to the steel and depending how its done will result in the end result. Ie if you hold d2 at a specific heat for the required amount of time to let the carbides and carbon come into solution you won't have issues like chipping and rust and getting that good grain structure known from the USA makers. The other thing that matters is tempering Temps and durations.Rust resistance doesn't really have anything to do with heat treat.
Though to be clear I’m not suggesting I have any knowledge about American heat treated D2 having significantly different corrosion resistance to Chinese heat treated D2, if they were both using the standard industrial practice it would be similar.
When I say standard industrial practice I am referring to the heat treatment. If the heat treatment is the same and the composition is the same then the corrosion resistance is the same.So, and tell me if I am putting words in your mouth, you are saying that, from your understanding, D2 with treatment A and D2 with treatment B, if A and B both use standard practice to produce a steel usable for a knife (acceptable hardness, strength, etc), should have similar rust resistance.
Edit: And I’m referring to the steel only and not surface finish or coatings.
They may not, a classic example is whether an upper or lower temper is used. A lot of stainless steel data sheets specifically recommend against the upper temper, which has been relatively commonly used in 154CM, ATS-34, and BG-42. The S110V datasheet has some experimental results.Now this may be unanswerable, but...if 2 heat treats produce, say, similar hardness, will they produce similar rust resistance?
Well... . Two knives of different recipes can be very different from one another but be the same hardness. Hrc can only tell you hrc. Not the grain structure of the steel or other things.Now this may be unanswerable, but...if 2 heat treats produce, say, similar hardness, will they produce similar rust resistance?
I wonder why it took so long given that D2 has been ubiquitous as a tool steel for so many decades. Should have been cheap.
There has been surge in the popularity of quality traditional slipjoints. Particularly American made.--KV
