I just checked the SK site and no Maverick listed anymore.
I guess they are all sold out!
They should flip, to much or to thick of oil , dirt ,pocket lint or the pivot screw to tight or badly worn egg shape. Not sure what kind of washers Buck is using now but I had a select that had brass washers that became shot from dirt and became very rough. Those are the only causes not to flip ? Your knife is new so I doubt it's any of the of the above. Give a little time it should start to free up. There shouldn't be any noticeable play. I will say you got to want it put your finger in the grove with some pressure and while keeping downward pressure pull your finger back as fast as you can against the flip guard. It should open as fast as an automatic with a nice snap soundI have found that if I just pretend the flipper tab is a gaurd and treat it like you can only open it via the thumb hole I am a lot more satisfied with Vantages in general. I have never had one that was a good flipper.
i care less about bearings. they are okay but not needed. id prefer a real useable size as in 3.5 or 3.75 or 4" blade.They should do a custom setup that's machined for bearings and not a washer
Wish I could keep that light shade, but hand oils and sweat have already darkened mine considerably.
Nice job!I've bought a few Vantage knives, so I expected it would need some tuning up but I had my hopes up that because it was a special edition with micarta and 20CV that it might not show up as rough as some, but such was not the case. It had the whole usual range:
As has been the case with other Vantage knives I've owned, I was able to resolve most of the issues pretty easily. I pulled it apart, cleaned it and gave it a bit of fluff and buff here and there. With the pinned construction take care of the four washers if you remove the blade. The lockbar tension was a bit too stiff for my taste, so I eased it back just a hair, tidied up gave it a couple of drops of oil at the pivot and carefully reassembled everything. Now it's just about perfect. It's centered, it I can light-switch or push-button it open reliably with no wrist action, and it's running just like the 13C26 version I keep in my carry rotation.
- Off center blade unless you tightened the pivot until it was tough to open
- Terrible action, even when loosened and off-center
- Very stiff detent
- Fairly late lockup (about halfway across)
I like the decorative backspacer, but the knife is a bit heavier than the one I usually carry as a result--if it wasn't pinned I'd probably switch to the barrel spacer from the 13C26 Vantage Avid I carry most.
Long story short, it took a tune up but I'm super happy with the result. Here's a photo for the pics-or-it-didn't-happen crowd:
