johnnytoxin
- May 24, 2010
Why would you have to use a Sharpie in order to put the 25 back together. Never heard this one?
He was talking about the assymetrical stop pin. If you take it all the way off you have to make sure it goes back on the same way so that the blade clears it when opening and closing. Removing it however is completely unnecessary as you only have to remove the screw from the non lock side when you disassemble. Clean it with a q-tip dipped in alcohol, lube the washers/blade, loctite the pivot screw, slap it back together. No need to move the stop pin at all. I feel its slightly easier to disassemble/reassemble the 25 than the 21.
