- Mar 26, 2001
No, your logic is sound.Nice job Keyman! Considered doing that to a standard smooth CF scale but one thing held me off. Since one is thinning the entire scale from the back, aren't you also thinning and thus weakening the "flange" (whatever it's called) inside each screw and pivot hole? The flange is what the screws press against to hold the scale to the frame. Thinning the scale also thins the flange and perhaps increases the chances of cracking the scale if one over tightens the screws or otherwise stresses the scale? Maybe I'm overthinking this. Maybe it's less of an issue with metal scales vs CF? Constructive criticism welcomed.
However, when i thin the standard RHK scale down, which has a thickness of .130", I take it down -.030" to a thickness of .100".
That still leaves .050" of material under the screw. .010" more then the factory RHK Skinny scale does.
I am within factory parameters.
RHK Skinny scale thickness .090" RHK Standard scale thickness .130"
counter bore depth -.050" Counter bore Depth -.050"
Remaining Flange thickness .040" Remaining Flange thickness .080"
