Slowly we will get there ......CNC belt grinder .This one solution is on half way ...half CNCvery cool idea with the tilt for doing bevels !
Yes ?
Well .......AC compressor in your car have inside electromagnet capable to hold you and me together , but they are round and about 4 inch dia. ........You just give me idea what to try nextYeah I wish I could find a way to make a magnet w/ an on/off switch... I toyed around with the idea of installing a series of electromagnets in the chuck but I don't think I have enough expertise in that area!
The problem there is that to true the chuck to the contact wheel, you will be grinding off material from the surface of the chuck. depending on how true it is to begin with, you could be grinding a good bit of the magnets off. These magnets do not like a lot of heat either, so that could be an issue.What if instead of grinding groove on CNC for magnet you make plate with ALL magnets .............one to one ?
i had thought about a mag lock for the chuck, but a few concerns-What about something such as this? https://www.aliexpress.com/item/280...ock-Holding-Force-For-Access/32814699730.html
Kevin , they look like very precisely made . You can true first chuck and after that to put magnet on ...That way , well maybe ..... they will need very little to true ?The problem there is that to true the chuck to the contact wheel, you will be grinding off material from the surface of the chuck. depending on how true it is to begin with, you could be grinding a good bit of the magnets off. These magnets do not like a lot of heat either, so that could be an issue.
maybe. But I think you are over thinking it. with the spaces, it is still plenty strong, and the grooves give the grinding dust a place to accumulate that makes getting it off easier.Kevin , they look like very precisely made . You can true first chuck and after that to put magnet on ...That way , well maybe ..... they will need very little to true ?
Will see ......BUT look in the price for used robot armsThats cool , really making me want one.
Natlek I am looking forward to that cnc grinder one day.![]()
Love it!So I Cerakoted everyting, only thing to do is making the stops for the tapering assembly.
Will see ......BUT look in the price for used robot arms![]()
One armed,I want to thank Travis Wuertz for this design. I could never afford his, but I did a fairly good job making my own I think. It actually looks and works better better than I had even planned! And being that it cost me less than $250 to build really is something! Took me a couple weeks to finish, but not bad considering I'm down an arm/hand LOL!
***EDIT*** Video posted on page 5!
