Yes, you NEVER will "lift" the blade off the magnetic chuck, blade must be slide off the side. It scratches the finish, but by putting some scotch tape over chuck it seems to work pretty good.
Here's a thread I started a while back showing details of my feed adjustment which shows the screws you're talking about.
https://www.bladeforums.com/threads/sga-feed-adjust.1563170/
If you look, you can see the nuts the screws are screwed into. The nuts are sunk into holes on bottom. I'm not sure why I used nuts rather than just threading the plate........... Surely I had a reason???
