Thanks! Now, I was gonna order my neobium magnets stateside, anyone have any idea what lb strength I should be looking for ?
You want the N50 or N52(strongest).
OK finally got it done and it works great. Its vertical and I am going to figure out to change that next. Need more information on the bracket to tilt it or how others have done it. Sent One Arm a note on that one. I would like to thank all the people who helped me through this. Without you all this would not have happened. Thanks to One Arm for the inspiration, Kevin McGovern and Ken H for many tips and tricks to get this together and last Stromberg Knives. Without Stromberg sending more in depth information I would still be trying to lay this out. You guys all rock, thank you much. I know she not as pretty as most, but here she is. Pardon my messy shop/storage area. I am slowly working on making it more of a shop and less of a storage area.
Well when I check here for example, I can get a 3 x 1/2 and either get it in 1/4 or 1/8" thicknesses. 1/8" thick has 14 lbs of pull, 1/4" has 35 lbs of pull, so I don't want to get the wrong one and have not enough strength or super strength to where I can't get the part off lol. The difference between the N48 and N52 in the same thicknesses is only 3 lbs of pulling force (35 vs 38) so it's negligible. I am considering getting the N48 ones that already have countersunk through holes then I can simply drill/tap and skip the epoxy step.There is no real spec as for "lb strength" of magnets. What you look for is the N52 which is the rating of magnets. I've got the weaker N48 which do ok. I'm looking at making another set with N52 magnets.
As far as length of tooling arm, that depends on your setup. I'd mount the surface grinding part first, then determine where the wheel should be to work.
I had one of these in the workshop. Never used it, took it apart and only used the bottom part with the table. I then shortened it, it now has a travel of 1 inch. The good thing is that it is adjustable and you can eliminate almost all play. (but still a chinese table hahaha)
Very nice Tony! I like the tilting ability... I can see that being VERY nice for long swords haha. what is the roll pin thing you used in the tilting of the arm?
So you are saying it would be one big magnet basically? A bunch of them side by side?What if instead of grinding groove on CNC for magnet you make plate with ALL magnets .............one to one ?
Yes ?So you are saying it would be one big magnet basically? A bunch of them side by side?
