- Jul 31, 2015
If you ordered this rail be prepared for a little surprise. It's a around 2 inches or a little more in height and will require some alteration to the tooling bar. But it seems to well made with no play but I wish it was half as tall.The linear stage sliding table was a little less precise than I wanted. If I were to build it again I would probably get this one instead:
https://www.aliexpress.com/item/GGP...4-Ball-Screw-Linear-Rail-CNC/32806395029.html
My parts came from China in 4 days except the wheels that came in 2 days.
I asked for 90, the hardest they had was 85. I think I'll be ok. harder is better.Kevin, or others that built the SG. For the wheel did you get a 90 durometer or just whatever hardness they come at?
Thanks,
Paul
Looking at my build, I think I'm needing to cut the tooling arm and off set the front portion under and maybe have to have a spacer between. With the wheel sitting on the arm and the ball screw rail stacked up with the slide rail the mag chuck is above the top of the 3 inch wheel.rabbit cut in the tooling arm that I need to lower the assembly
I'd actually be happy if mine worked out this way, as I could A. Use the wheel separately by removing the bar below. and B. it would remove the variable of me not notching my tooling arm accurately.Looking at my build, I think I'm needing to cut the tooling arm and off set the front portion under and maybe have to have a spacer between. With the wheel sitting on the arm and the ball screw rail stacked up with the slide rail the mag chuck is above the top of the 3 inch wheel.![]()
If you ordered this rail ( https://www.aliexpress.com/item/GGP...4-Ball-Screw-Linear-Rail-CNC/32806395029.html )be prepared for a little surprise. It's a around 2 inches or a little more in height and will require some alteration to the tooling bar. But it seems to well made with no play but I wish it was half as tall.
First point: These aren't designed to be as accurate as a real surface grinder Second point: Using a 3" wide belt and 3" wide wheel means that the entire surface is ground in a single pass. there is no need to move the wheel across the piece. Once the mag chuck is installed and ground flat to the wheel, they are parallel. So even if you tracked a narrower belt across a wider wheel, it will still be parallel. Keeping in mind that it is not designed to hold the tolerances offered by a true surface grinder.Did anyone actually measure the flatness and parallelism obtained by this kind of setup?
What is making me wonder is you don't have a transverse movement of the wheel over the piece width, which is the key point of a surface grinder.
Ken, it is 2 3/16" high x 3 1/8" wide x 7 1/8" long not including the wheel and crank which add 2 3/4". It does present some issues concerning the relationship between the wheel and the chuck.You mention it's 2" high, how wide and how long?
I believe current Hill took about an an inch off of his tool arm to make clearanceKen, it is 2 3/16" high x 3 1/8" wide x 7 1/8" long not including the wheel and crank which add 2 3/4". It does present some issues concerning the relationship between the wheel and the chuck.
Well, my rail is the smaller one. So I didn't have to take so much material off of my tool arm. With the larger one I would choose another design and mount.I believe current Hill took about an an inch off of his tool arm to make clearance
I looked at doing that but I have two Bader 3s which use 1.25 inch arms. One Bader can go horizontal but the other doesn't and I want to use my surface grinder on either one. So I put two pieces on tool bar stock side by side under the slide table. Those mount under the main bar that goes in the grinder with a .5 inch spacer between (drops the chuck 1.75 inches) at a 45 deg angle which will allow use in the vertical position. Once I get or make spacers to get the wheel 3/8 inch or so above the tool arm the chuck will be pretty much centered on the wheel. I'd of posted but imgur won't let me on right now.I believe current Hill took about an inch off of his tool arm to make clearance
Post pictures when you get a chance pleaseI looked at doing that but I have two Bader 3s which use 1.25 inch arms. One Bader can go horizontal but the other doesn't and I want to use my surface grinder on either one. So I put two pieces on tool bar stock side by side under the slide table. Those mount under the main bar that goes in the grinder with a .5 inch spacer between (drops the chuck 1.75 inches) at a 45 deg angle which will allow use in the vertical position. Once I get or make spacers to get the wheel 3/8 inch or so above the tool arm the chuck will be pretty much centered on the wheel. I'd of posted but imgur won't let me on right now.
I got the same table that current Hill got. So I'm not familiar with yours. Is there a screw that will put some resistance on the table or screw that you can tighten?
I do not have any experience with these kind of rails, but I was surprised to be able to move the table by hand. I could build a stop on it, how would you guys proceed? (I have a backup rails wenn this one is not working out).
