CorporalChaos
- Dec 11, 2006
What a fascinating thread and an amazing level of craftsmanship.
In addition to the wonderful knives and leatherwork, I'm really digging the behind the scenes look at how it's all done.
Which brings me to a few questions if I may. For hardwoods like, mesquite, walnut, ironwood, osage, and so forth, do you do anything to stabilize them or do you use as is? If no stabilization, is there any risk of them drying out and cracking over time? Do they need to be oiled periodically with anything to prevent cracking?
On the steel front, you mentioned you do most of the grinding after heat treat. How do you keep the steel from over heating while grinding after the heat treat, just dunk in water every pass or so? Have you ever tried to do your own heat treating and if so, why did you decide to switch to out sourcing it?
Regarding the hamon on your carbon blades, if the blanks are heat treated and then final ground, and you still end up with a nice hamon, why is it necessary to try to avoid that area when polishing? Or did I misunderstand what you were trying to convey on that part?
You and your wife are real artists. I had a friend that was a rather talented leatherworker down here in Tucson. Unfortunately he passed away several years back. I wish I had the foresight to pick his brain and learn the craft from him.
