My Extreme Spitfire also has slight up and down play. It doesn't really bother me, but I was a bit surprised that it had any play. My standard orange Spitfire has virtually no vertical play.
some company's do constant improvement, like Spyderco, what's Bucks perspective on that approach?
The knife looks great and nice to see a premium steel being used. When will they be available?
Nice knife with premium steel. It will be a great knife for steel junkies. Plus it's a start to other products offering it.
I'm curious, what does sandwiching S90V between CPM-154 accomplish? I don't know enough about steels to really know any better.
I like it. How much is this bad boy?
I would like to know the tech behind sandwiching the steel too.
Has Buck solved the lock up issues that the earlier ones had? Specifically, the up and down movement in the locked position was reported to be pretty bad.
Exactly. The Spitfire Extreme I just purchased has that same up/down blade play when the blade is locked open as the standard factory ones I have do. I was hoping with the upgraded model the fit might have been tweaked to eliminate that. I do hope that this issue is looked at with this other new premium version of the Spitfire. Ti slabs on that blade steel would be pretty cool as well I think.
I've noticed it's hit and miss even with the Extreme. Some are tighter and some are not. Personally, it doesn't bother me at all. It stays solid when cutting. You guys are teaching me all the things I didn't know I was supposed to be annoyed with!![]()
You are in an excellent position to ask hard questions of Buck on this. The Spitfie could become a long time pattern but they've got to address the blade play and make it go away.
Oh believe you me, I am asking the questions. As a dealer, I'd much rather send out a 100% satisfactory knife. You guys like it, and I like it. Hopefully we can get them there! Thanks for the heads up on the Yellow Jacket!
I'd definitely be up for an 830 Marksman in S90V : )
Just curious if there's been talks with other handle materials like g10, micarta, or Ti for instance. Also, I do hope with your talking to Buck about the up/down blade play they might fix that tolerance issue. Most are just too loose. I know at their price point, for the standard model, and the design itself, many lock backs with have a little up & down play. Not really such a big deal. It's just too much with the Spitfire. Particularly when many Spitfire buyers likely own a 110 as well, which is reasonably priced at the big box stores, and it generally locks up pretty solid when it opens. So your new Spitfire arrives, and your left with a letdown cause it feels cheap in comparison. And I do wish they'd use a different pocket clip so you could swap it out for a deep carry. Use a standard hole pattern. Lol.
Anyway, glad to see your continued projects with Buck!
The Hornet is up for presale!
http://www.skblades.com/product-page/80bc3aea-eeb8-0b02-86be-3a7a7b3b6303
