A little steel wool and a vinegar bath.
I totally agree with those who don't feel entirely comfortable with a paracord tied around their neck. Here's what I did:...I don't know if I feel comfortable with it hanging from my neck on para cord. Not much of a rational reason for it, just creeps me out a bit. Bad memories of garroting chip munks in a previous life maybe.
http://www.bladeforums.com/forums/showthread.php/624614-Neck-lanyard-my-secure-amp-safe-solution
Hope that helps.
If the chain breaks, then your lanyard gets progressively smaller, right? If it breaks too far from the "clasp", then you need to go buy a new one.I either gut the paracord and put a breakaway chain inside.
Or I use the snap clasps like they sell for nurse's ID tags.
i ended up wrapping my sheath, which makes it quite versatile as a belt loop system. i can slip a belt under that, either side, for vertical or horizontal carry in any of 4 orientation or some crazy canted angles if i want:
I've got to find out how you did this!
use the included cord, remove the cord guts, now you have a flat tape
make one end pointy by a tape "fid" - that is, just wrap some packing tape around one end, tight, in a slight cone, non fray point...
and figure it outstart with a basic X shape, then notice you have miles of cord left. then make some more crosses. eventually, it'll work out.
tip: put the cord through the top two, or botton two holes, both ends, and center. weave with both ends.
the picture says everthing
glad you like it
