How do you carry your knife?
Folders are always tip up for me. If I'm wearing pants or cargo shorts, I carry clipped in the right front pocket. If I am wearing sweat pants or athletic shorts, I carry clipped to the waistband on my right side. Really don't carry fixed anymore.
And there's a slipjoint in my pocket.
I carry tip down - right back pocket. My thumb just falls into place upon removal and my thumb rotates the blade for a positive lock-up just as the knife clears my side. I've tried other carries and nothing comes close in speed and ease of deployment. Even while crouched down working on something, the back pocket is readily accessible (unlike the front pocket).
Most of the time it is a small folder in the right front pocket. Clipped or not. This is my main carry.
Horizontal belt sheath, right side, for larger folder or multi-tool if needed. Rarely used.
If I carry a fixed blade (5 in or less), it is normally on left hip but I have been known to carry right side or in pack. Pack carry for FB is slowly winning out.
I don't own a machete yet but, I am not sure where I would carry. Any suggestions?
Usually front right pocket clipped tip up but a small fixed blade like a silent soldier or similar works well on left hip for cross draw
Back right pocket. I usually carry a pistol in my right front pocket, so the knife was moved to the back right pocket.
I carry a small fixed blade in a crossdraw or horozontal belt sheath, because I always carry a handgun strong side. There's also either an Alox Cadet or small stockman in my right front pocket.
It greatly depends on what I am carrying, where I am going, and what I will be doing.
I do front right or left pocket depending if the knife is tip up or down, I always have the blade against the back seam. Mostly tip up, right pocket, based on my collection then I always keep a zippo in the coin pocket.
- Traditionals loose in pocket
- Clipped folders in right front pocket
- Work knife in horizintal sheath (see pic)
For the last few months, I've been carry as follows --
LFP - Kabar rigging knife
RFP -- Buck 502 deep, Pro-Tech TR4 tip up clipped at the rear of the pocket
BLP -- BK11
4 and 8 o'clock - Paired fixed blades which vary depending on whether I'm working on the farm or going to town (max 5.5" blades for public carry in Texas)
Belt pouch for my EDC unless I'm wearing a suit in which case it's a lot smaller knife and slips into a pocket.
Very often it is a folder with a lock and a pocket clip and I just clip it in right front pocket.
But . . . some times the knife is thick handled. I prefer thick handles like the stock Griptillian. The thick guys I carry in the ammo clip pouch shown here on the far left. Some folders I prefer with the pocket clip removed so they are also carried in this pouch. Two examples are the Cold Steel Ti Lite (vastly thinned FF blade) and the Spyderco Para Military both shown next to the pouch.
Then . . . I very much like the full size trappers. They have no clip and are too long to carry in my pants pocket because they go side ways in the bottom of the pocket and teeter across my leg. The trappers are too small for the ammo pouch and tend to flop around; might even fall out. So up until recently the best pouch I could find to carry them for easy access is the little black pouch shown with the top flap folded back and tucked behind the back and the metal belt clip.
I like metal belt clips; they allow me to clip the pouch to my belt without unthreading the belt, obviously, but also allow me to put my knife on the band of pants with no belt loops like the thick, old, sweat pants shown in the last photo and onto the edge of various bags I carry (walking, biking, working).
So I am not a fan of pouches that only have a belt loop and no clip.
Enter my latest knife pouch :
Ta-da ! ! ! the Boker Trapper pouch. Brown embossed leather. Quite nicely made / very even embossing and double stitched with heavy thread.
Shucks . . . it has only the danged belt loop . . . and I really like everything else about this pouch.
As Seven Of Nine always says "You Will Adapt". A tiny, tight, loop of paracord and a key ring hook and . . . .
Who knows . . . this could be good. Very comfortable so far / doesn't dig my side when I sit down like the first clip-over-the-top-of-the-pants pouch (the black one with the folded back flap) .
Time will tell.
The pouch was a bit stiff when new. I wanted to form the leather to the knife and since the knife I carry in it is C75 carbon steel (easily rusted) I didn't want to wrap the knife in plastic and soak the pouch in water (I was pretty sure the plastic would tear and the knife would get messed up. I put the knife in the pouch and carried it for a couple of days under my shirt on a big loop of paracord around my neck. The humidity and the heat seemed to do the trick well enough. It is not a nice tight custom fit but the knife fits well and has the right amount of hold on the knife. It is pretty dry here and not getting hot during the day so the knife did not rust at all from sweat.
Brusiedmeat,
Will you show me the "pry bar" ? I see two pocket clips; is it a knife ?
Size of knife does not impact where it goes, with one exception.
A traditional rides in my left front pocket.
A modern folder is clipped in my right front pocket - anything from an old CUDA EDC to a ZT 0200 KW (to give examples of the size range)
The only exception to that is a Spyderco Military; which, when I carry it, gets clipped in my left rear pocket.
I sporadically carry a smallish fixed blade - depending on the knife it may be in my right rear pocket, or on my belt.
Traditional or locking folder in loose in bottom of right front pocket unless I am pocket carrying derringer, then knife gets sent to left front pocket.
