So thread revival: I cannot seem to get the hang of stropping! I need to figure out the proper angle. Please help I have tried a smaller angle I have tried a larger angle. I want to get a razor "hair popping edge on my 5/32 Alabama Damascus steel Hiking Buddy using the flexxx strops. Any suggestions?
Hey Bartlax, just off the top of my head, I think the following are the things you should consider/ask yourself:
1. Will you be using the sandpaper that comes with the complete kit? Does the package as a whole serve your application well? (as in do you sharpen your knives often in the field).
2. The strop on the complete kit, I can't imagine it being longer than 5" and the other strop is 8" I believe. If you're looking to use this as your primary stropping kit at home, then my experience is longer the better (that's what she said). In all seriousness though, depending on the type of grind you have on the blade, I've found in my experience that having a longer strop makes a big difference in efficiency.
3. You can always get sandpaper from....well anywhere. Then again, you could also make your own strop at your specification, and just buy compound.
Josh
