- Nov 20, 2005
It only matters if you think it matters!
Not my work though. All I know about steel I learned from the Conan movies.Thank you so much. Such great work and rich info.
This. I had a chubby M390 blade that cut far worse and held an edge no longer than a SAK.Blade geometry is the most important parameter in cutting performance. Proven fact.
After that is alloy and temper. Alloy and temper can't be separated, although many folks try.
Reading these replies has made me realize that it's not so much the steel, it's the price of better steel that puts me off using the knife as hard as I'd use a relatively affordable and replaceable knife, and I've broken as many blades made from good steel as 'bad' steel (aside from 3V) by driving them through knots or hacking and boring at hard wood. I found powdered steels tend to chip as well, and it takes serious work to re-profile a chipped edge, which brings me to the issue of sharpening. The S90V on a Benchmade that I owned for a time was a nightmare to just touch up after use, let alone re-profile the edge with a better geometry. Same for a Manix with a Maxamet blade, I wound up gifting both to friends because they were more trouble than they were worth to me. These cheaper steels are almost impossible to not give a razor edge to in just a couple of minutes.
Plus you don't often get knives in more specialized steels that are designed to be put to work. They're more pocket jewelry and the most I can see anyone using them for is cutting up a cereal box to fit in the kitchen trashcan. Or the Amazon Prime box your air fryer turned up in.
The more I think about it, the more I wonder what the point is, but I realize I'm very much a certain type of user that manufacturers don't really cater toward because it's not generally where the money is to be found.
I think you would be very happy with S30V or S35V steel for your needs. What do you do that breaks blades?Reading these replies has made me realize that it's not so much the steel, it's the price of better steel that puts me off using the knife as hard as I'd use a relatively affordable and replaceable knife, and I've broken as many blades made from good steel as 'bad' steel (aside from 3V) by driving them through knots or hacking and boring at hard wood. I found powdered steels tend to chip as well, and it takes serious work to re-profile a chipped edge, which brings me to the issue of sharpening. The S90V on a Benchmade that I owned for a time was a nightmare to just touch up after use, let alone re-profile the edge with a better geometry. Same for a Manix with a Maxamet blade, I wound up gifting both to friends because they were more trouble than they were worth to me. These cheaper steels are almost impossible to not give a razor edge to in just a couple of minutes.
I have tried very hard to break a blade and have only broken one in my entire life. That was when I was a kid and I believe there was an imperfection in the steel. But I really didn't know enough to even look then.
