- Sep 28, 2015
thank you Irishman. Gonna give it a try.
Why would I presume to call you something that you yourself won't use.In my many years on the interwebs, you are the very first to get it.
I think the whole concept of pull strength should be standardised.
Until then its completely subjective and slightly mysterious as to what exactly the difference between a 3 and a 6 or a 7 and 8 pull actually is.
I think that the standard of which folks judge a pull is the pull of the SaK, which is fairly uniform along many models. And that pull is noted to be a "5". Most people to seem to have a SAk and then can make a comparison among knives and among others in a discussion.
Thats the exact reason a standard would be helpful.You could compare a description of an unseen knife to one that you have in hand. Knowing that its a number 5 for instance could be the difference between purchasing or not. .....maybeSeems to me it's inherently subjective. Your 4 pull might be a 7 to me (because I'm a weakling), no matter what a hypothetical pull-measuring robot says.
BTW - I agree with the Poster who stated they never carry the Buck 301 because of the light springs. I have two of the newer ( mfg by Buck) 301 stockmans
and the light spring pressure makes me slightly uncomfortable. Conversely my older Buck 301 mfg by Camillus is just fine.
That allows me not to have to type out my own answerI like about 5or 6, any stronger and they are normally sold.
The pull isn't the issue for me. It's the spring tension when the knife is opened. I prefer a stiffer spring for the most part unless it's a sub 3" blade. I also carry multiple blades so i have something that locks if i feel like i need that security. Also have a fixed blade too....
My Queen 41L has the strongest pull of any of my knives. Sadly, I wish it were lighter...it is a linerlock after all so I don't need it to be so tough. With that being said, is there a way to lighten a strong pull a bit? The pivot is clean and oiled..just a strong spring.
