That is really, very funny. I wish I had thought of that.
Absolutely. If you took a blade and put multiple nicks on it from tip to tang, the required force to open would increase as you approach the tang.Leverage! Doesn't the length of the blade, depending on the placement of the opening nick have something to do with the perception of "pull"? I'm just wondering?
Yes. To my point. Leverage! You know, Atlas and all thatAbsolutely. If you took a blade and put multiple nicks on it from tip to tang, the required force to open would increase as you approach the tang.
I believe this can be a big factor, and may be why I often have more trouble opening the smaller secondary blade than the main blade on a jack knife, despite it having a thinner spring.Yes. To my point. Leverage! You know, Atlas and all thatSo, all things considered, the longer the blade and the further the nick or pinch point the softer the pull?
I guess it's obvious, but I agree Rachel. I've found that the smaller secondary blades give me more trouble opening. I mentioned earlier in this thread, I have a Washington Jack that I can hardly open without cutting myself!I believe this can be a big factor, and may be why I often have more trouble opening the smaller secondary blade than the main blade on a jack knife, despite it having a thinner spring.
I think the spring is still the main factor when it comes to pull strength. My S&M English Jack has both blades at a little over 3.5", and they are both tough to open.
That being said, the sheepsfoot is probably an 8 while I'd give the clip a 9.
The spring makes them both tough to open, but the nick placement probably does add a level on the clip.
Wouldn't makers take spring strength, blade length, nail nick placement, etc into account when designing a knife?
Good pun.Perhaps they should but not necessarily the case.
I like the pull to be somewhere in the middle - around what might be called a 4 to a 6, I guess. I imagine if the pull is really heavy to me, that it can take it's toll on the knife where the wear points are. How much longer will a pivot pin or center pin last if it has less stress put upon it? The spring(s)? Tang(s)?
I tend to think this way about all mechanical things though. Makes me go easy on all my stuff. If something takes a bunch of force to operate, I start to think of where its going to break. Probably never happen with a folding pocket knife, I know. Oil them joints!
How Much Pull is Actually Needed?
Enough to be satisfying when you work the action of the pocketknife.
I don't see why not, as long as it isn't too soft a pull, and you aren't expecting a huge snap.Is it possible to have soft pull with good snap?
