- Jul 23, 2015
Tough is impact resistance without fracture. Thicker is inherently tougher. This is not in dispute. But tough doesn't "mean thick". It seems axiomatic so I am struggling to find another way to explain it.
Any thicker knife NEEDS to be tougher, because it's going to take More force to go through your target, also dulling sooner than a thinner blade of same steel and heat treatment. (Usually)Tough does mean thick though. If everything else is equal the thicker stock and/or thicker edge/apex will be tougher. No matter the steel.
If I am wrong here someone correct me. Take any steel in any knife and make the stock thicker or edge thicker and it will be tougher than it was previously.
I didnt say they were the same. I said the thicker a knife is (all else being equal) the tougher it will be. Simple as that lolNo.
Yes!
But why you think they are the same is a mystery to me, and I don't know how to untangle these two separate concepts for you.
Thats not really relevant to what I said. I simply stated all else being equal the thicker you make a knife (especially the edge angle) the tougher it will be.Any thicker knife NEEDS to be tougher, because it's going to take More force to go through your target, also dulling sooner than a thinner blade of same steel and heat treatment. (Usually)
You are taking what I said out of the context. Context matters. Ill repeat this for the fourth time...@Dr Rez "Tough means thick" is an incorrect statement that implies you cannot have a tough blade that is thin. I agreed to the part you were correct about. @Crag the Brewer also correctly pointed out that thicker means more force required to separate material.
This blade is .140" MagnaCut, and has a full height flatvex grind to about .020" behind the edge. It is not the thinnest of the stocks discussed in this thread, but relative to its size and the amount of force it can generate, it is super thin.
It stood up to ten minutes straight of this with no damage at all.
Ok...? Now take that same knife and make it thicker stock and a thicker apex. It will be tougher.This is a .09" thick wharncliffe full height ground to a tapered point with a bte thickness of .008" all the way to the tip.
There was no tip breakage.
Perhaps you didnt see the "all else being equal" part....Of course it is relevant. The increased demand on the structure of the knife at least partially negates the practical toughness thereof when used hard, depending on the use and other factors, of course, such as geometry and heat treatment.
Perhaps it is my fault for not being clear
It wasnt just tough is thick though...it was the complete statement I made which you conveniently keep acting like wasn't part of the comment in order to keep being right for some odd reason. You are being fallacious at best, dishonest and rude at worst.Exactly.
Yes.
Of course I did, but the change in thickness affects every other factor as well, making the relevance of Crag's point clear.
Bottom line. "Tough is thick" is a backwards and misleading way of saying the factually correct statement of "thicker is tougher".
Then be respectful and don't antagonize. I have no issue with you if we can debate without being rude and condescending in our replies. Running to a mod awful quick....just be respectful.@knarfeng I fear for the direction this thread is heading in.
Well technically both, but each contribute to being tough in different ways. As mentioned a thicker apex is going to significantly increase impact resistance for example, while a thicker stock would increase the blades ability to withstand snapping or bending when using it for those dirty (probably non knife) jobs many of us love to do.I think the misunderstanding here is that Dr. Rez is talking about a thicker edge? And David and Craig are speaking to thicker stock?
Is this correct Dr. Rez?
Fair enough, I think our different communication styles led to me thinking you were intentionally trying to be condescending. I in no way meant to be so myself if I was.@Dr Rez if you feel I have antagonized you or disrespected you, I sincerely apologize. Nothing I said was meant to do either of those things. You said correct me if I'm wrong, and that is what I did. Perhaps my directness was taken as rudeness. It was not meant to be. And I have agreed every time you restated that thicker is tougher, so I don't see how you think I am ignoring that point.
