Thanks Karl for that detailed how to. I saw you post this on tradgang without all the pics and I didn't quite follow it. Now with the pics I think I got it and I will try this method on the next guard I slot.
I think it was very good of you to post your technique. There are, of course, other ways to skin that cat. A machinist "type" might approach it a little differently by "going by the numbers" instead of scribe lines, and perhaps eliminate a couple steps. But your results speak for themselves. :thumbup:
Karl - I'm also new to this(very new). Are you using a two-flute or a four-flute end mill?
My understanding is: two-flute is for plunge work and four-flute is more suited for milling/routing chores.
Thank you,
Peter
Nice thread Karl, those are great photos to go along with the description of your process.This should get a whole lot of guys started that would otherwise avoid trying a hidden tang guard.
What is the reason for milling the slot in progressive steps?
Thanks Karl![]()
I'm not talking about cutting full depth in one pass. He made his cuts by plunge cutting a little and traveling in the X-axis a little, and then did that progressively across the slot. I've never seen it done that way, so I'm curious what the reason behind it is.![]()
